Need to update speackers?
Johnnybass
Hi i have a onkyo txsr303 65 watt a/v recever.it has polk rm6005 on it for sat's and a ps10 sub. what speackers would be a good upgreaid for this recever?? or is it better to just up everthing??
Thanks john
Thanks john
Post edited by Johnnybass on
Upgrading everything would be best. But if that's too much. Start with the Fronts, then the Center at least.
Look for efficient larger sized bookshelves or towers like the M series or the TSIs.
Depends on your budget. You have some limitations in terms of the power the Onkyo can generate so I'd stay with the above lines!
Cnh is right on the money for the course to take. Thats how i upgraded, Rm6750, Rti6 bookshelves, and ultimately Rti-a7's. Of course like he made mention, bring up your center also, which is really your most important speaker.Receiver: Pioneer Elite SC-05
Amp: Emotiva Xpa-3
Front L/R: POLK Rti-a9s':D
Center:POLK Csi-a6
Rear surround's:POLK Rti-a1s'
Sub: Klipsch Synergy sub-12
Sony Kdl-46w4100 46" LCD
PS3
Audioquest type 4 wiring. -
Thank you. i'll look into getting everything uped. i do have a older unit
a buddy looking at getting a 7.1 system.where do the other two speackers go?? i have a 5.1 and didnt know when he asked
Thanks john -
I run a 5.1 system myself. 2 in fact. The surround back go a few feet or so depending on your room directly behind the listening position as the surrounds are pretty much on either side of you.
Here's how dolby say's to set them up.Johnnybass wrote: »a buddy looking at getting a 7.1 system.where do the other two speackers go?? i have a 5.1 and didnt know when he asked
Thanks john
http://www.dolby.com/consumer/home_entertainment/roomlayout2.htmlDenon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra) -
Thats sweet.thanks:D
