New setup
Admfly
Looking for suggestions on where to place my surround speakers based on room dimension. I have an 11'5 x 30 ft room with vaulted ceilings approx. 12 feet high. The listening position is approx. 13 feet. The room is essentially split in half...the back half has a pool table and not used for sitting space. Where would be the best place to put the FXI A4s??? I have the following equipment...
Dennon 2308 CI receiver
Polk RTI A7 towers
Polk CSI A4 center
Polk FXI A4 surrounds
Polk PSW 505 sub
Thanks for any advise or assistance offered!
Polk RTI A7 towers
Polk CSI A4 center
Polk PSW 505 sub
I would start here Dolby and before you make any permanent mounts or run in wall speaker wire experiment a little and try a couple different location options. Then go with what sounds best to you.
