Audyssey question
rallyshark
I was wondering if an audyssey mic from an Onk(audyssey 2eq) would work with my marantz(multieq) receiver? Is it the same mic, or do I have to have one specific to my receiver? The reason I ask is because my friend has the mike with his Onk HTIB, and I was going to buy the mic for mine tomorrow. If the mic will work though, I see no reason to buy one if I can just borrow his. Thanks in advance for your help:D
Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car?
Sony DVPCX995V
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
Post edited by rallyshark on
I have no idea on this, but in case no one knows, I would guess yes and no. I'm thinking that the mic's are calibrated to a certain degree to work with the program (audyssey/multieq) so the mic might work, as far as function, but the results might not be that good.
I take it you lost your mic? Your AVR does have Audyssey correct?
Assuming that it does...I don't see why it wouldn't work. All it is, is a microphone. All of the calculations and calibrations are done within the AVR, so I'd imagine it would work.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Actually, no I didn't lose it, I never had one. I purchased a Marantz SR6001 factory refurb and it didn't come with the mic:(Sony 40" LCD
Sony DVPCX995V
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
Honestly, I'd just buy the Marantz mic. Each brand uses different mics, and the general response curve of the mic is taken into account in the receiver so that Audyssey gives you a more accurate reading. I'm not sure what the Marantz mics look like, but I know Denon's mic is vastly different from Onkyo's, so unless the Marantz mic looks identical to the Onkyo one... get the Marantz mic.
Dumb question: Have you tried calling Marantz and telling them you bought a refurb and didn't get a mic? I'd be surprised if they didn't just send you one.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
From the Audyssey FAQ......
Is the microphone calibrated?
Yes, the microphone is calibrated to a 1/4" industry-standard measurement microphone. The correction is applied to the measurements as they are being taken. It is important to use ONLY the designated microphone that comes with the product as the calibration curve built-in to the product is specific to that microphone. It is also critical to point the microphone upwards and to place it at ear height. Any other microphone will have different characteristics and thus will not produce the right results.
http://www.audyssey.com/faq/index.html#miccalibration
Hope that helps,
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
Thanks guys:) I ordered my marantz mic today:DSony 40" LCD
Sony DVPCX995V
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
I bought my marantz 5002 from accessories4less.com and it didnt come with a mic. But when I called they finally sent me a Audyssey mic instead of the MRAC-1 mic. But the mic has worked well to measure distance and volume of each speaker. However, for some reason it wont measure the subwoofer. I actually have to unplug the sub or I will get an error during the calibration.Marantz SR5002
Polk Lsi15 (left and right)
Polk Lsic
Hsu v2.3 sub
Crappy rears (will upgrade to lsifx eventually)
Amp? still need one
Samsung 5064 Plasma
Panasonic DMP-BD35
Tivo HD -
Whats the error ? might be another problem and not micSpeakers: SDA-1C (most all the goodies)
