SDA 1's
Toolfan66
Anybody here have/or have had the SDA 1's as 2 channel set up? If so what are your thoughts on these?
Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s
SVS SB16 X2
Post edited by Toolfan66 on
I had the 1c's and they're great. That's the only SDA1's that are worth buying IMO.
I have 1C's in a 2 ch setup,, driven by a tube amp, a tubed pre and a ss CD,, I could not be happier. Soundstage is wide,imaging is spot on. The rdo replacements,are,, IMHO a must,at least for my ears. Mine seem to perform effortlessly in this configuration,without any listening fatigue.Price? I paid 375.00 for a mint original owner pair.Paired with the right components(synergy) it is hard to beat. Good luck.JC approves....he told me so. (F-1 nut)
TOOLFORLIFEFAN wrote: »Anybody here have/or have had the SDA 1's as 2 channel set up? If so what are your thoughts on these?
I found these in Boulder and know your in Denver area, I thought you might be interested
http://denver.craigslist.org/ele/1041825601.html -
I'm very pleased with my SDA-1's...
POLK SDA-1 SIGNATURE SERIES
POLK RTA-12
POLK 7C -
Signature editions? Very nice...those are hard to come by.
Look like they're in great shape too.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I too have 1Cs as mains for my 5.1 system which also my mains for 2 channel. They are fantastic speakers. I have upgraded the tweeters to RDO194, Using Ben's Silver ICs between my Denon AVR and Carver TFM-45 and lastnight hooked up AQ Type 4 speaker cables.
Never need the sub for music. They are that good.Speakers: SDA-1C (most all the goodies)
I would recommend the 1B's or 1C's. 1C's being the most desirable, which are fantastic.
Older Polk SDA, like the original SDA 1 use the second tweeter (side by side) to reproduce dimensional information which can sound a bit "phasey" and pretty unnatural at times.
Further research from Polk realized that higher freq dimensional information was unnecessary and did away with it.
While the original SDA 1 and 1A's are decent they don't represent the "best" SDA experience. Get the 1B's at minimum and the ideal pair of mid-size SDA's are the 1C's.
Hope this helps
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
comfortablycurt wrote: »Signature editions? Very nice...those are hard to come by.
They are hard to come by and are really nothing special (sorry to the original poster). But, they are SDA's which means they are better than most speakers of that time out there .
I would never pay extra or hold out for the Original Signature editions of SDA 1's."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Those are SDA 2B's..........certainly a great performer and part of the last generations of SDA's. The price is a bit on the high side, but if they are minty, have the cable and are local pick-up that's a fair deal.
SDA 2B's will get you about 85% of the 1C's. The 1C's have a bit bigger, taller, deeper soundstage and better, more extended and solid bass response; especially in a larger room."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Power them up and they rock.
B. -
Don't forget, 1C's and SRS2's are almost identical."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The SRS2's are more desirable and a bit better than the 1C's (larger PR and better cabinets). When I made the statement as the 1C's being the most desirable; I meant of the SDA 1 models.
SRS2's tend to be pricier and harder to find all things being equal (price, cond., location, etc....) it would be a hard choice between the 1C and SRS2 with the SRS2 (especially if they are the later gen) would win out.
The early SRS2's have all the same model driver and the "mixed" driver revised version is a bit better, IMO.
