TSi 200 Speakers
Kingfish99
I purchase a pair of PolkTSi200 bookshelf speakers and a pair of Sanus 30" steel speaker stands.
I thought that I read somewhere that I could screw mount the speakers to the stands.
Does anyone have any information on this?
Charles
Charles
Post edited by Kingfish99 on
I'm sure you could screw mount them, but I wouldn't myself. They're going to forever have screw holes in them afterwards.
Which specific stands did you get? Do they have holes to accommodate screw mounting? If they don't...you could probably drill your own in them if you have a decent drill.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
If the bookshelf doesnt have any threads in the bottom try using reusable adhesive (also called poster putty).
something like THIS
