Subwoofer connections?
mpanko
mpanko Posts: 2
I just purchased the RM7650 system. My Sony system only has one RCA output connector for the sub woofer, but the Polk sub woofer has a L & R connector. Do I need to get a splitter to connector to both L & R connectors?
Post edited by mpanko on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited February 2009
    No, you can just hook up to one of the inputs on the sub. LFE signals are mono signals, so only one of the inputs is needed.
    You can use a Y-adapter if you want, but it's not necessary.
    By the way, welcome to Club Polk.:)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • mpanko
    mpanko Posts: 2
    Dear Comfortablycurt:
    thanks so much for the response!
  • comfortablycurt
    You're quite welcome.:)
  • Mike21
    Mike21 Posts: 252
    Hi M
    If you happen to already have a Y splitter, I would try it to compare with just the single cable in to the sub. But, the single cable should be fine, so I wouldn't spend any extra money for a Y cable.
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • BlueFox
    BlueFox Posts: 15,250
    mpanko wrote: »
    Does your Sony have pre-amp outputs. These connections on the sub are for connecting it to your AVR/pre-amp via the pre-amp outputs, L/R. Generally, this is preferable since using the LFE output requires setting your speakers to small, and this introduces filters into the circuit to extract the low freq signal, which can degrade the sound quality. All the energy needed for the sub is in the front pre-outs.
  • avhomedesigns
    avhomedesigns Posts: 29
    either one is fine
