cooling avr
Knucklehead
Knucklehead Posts: 3,602
edited February 2009 in Electronics
I have 3 brushless fans to install on my H/T cabinet...is it better to pull heat away from the AVR or introduce cool air to the unit. My cabinet has a plexi glass door on the front which i like to keep closed due to the kids curiosity. The cabinet contains all of my equipment. thanks for the input.
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan
Post edited by Knucklehead on
  • CaligulaPolk
    CaligulaPolk Posts: 1,650
    Damn kids' curiosity! my 15 months old love to touch my electronics so wife decided to buy me sauder rack for v-day. I think you will better off to introduce cool air to the unit. Unless you want extra heat in your house or more hot in your cabinet to keep the lizards warm :D
    I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
    My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
  • Knucklehead
    Thanks, makes sense, I just hope these things arent too noisy.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • CaligulaPolk
    i also suggest you place cabinet near Air conditioner outlet, it would help.
    i think itd be save money if you tape a tube from ac outlet to your cabinet and let A/C do the work and less noises :D
    :p
  • acsubie
    acsubie Posts: 773
    i have a fan on top of my onkyo 805 and it is pulling hot air OUT of the avr
  • Knucklehead
    WOW!!! thats a great idea! Now I know why you guys get paid the big bucks!
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • leroyjr1
    leroyjr1 Posts: 8,785
    I have a 110volt 4 inch fan on my cabinet for my ps3 and I pull the air out(less dust in cabinet). It's a little too noisy for my taste also.
  • Knucklehead
    leroyjr1 wrote: »
    thats what im afraid of...my dang xbox360 sounds like its getting ready to take off as it is since micro-suck fixed it. :rolleyes:
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • leroyjr1
    What size fans are you using, and are they 110v/12v? I'm looking to get some smaller one's. Also what db rating did they have on the box?
  • hearingimpared
    hearingimpared Posts: 21,136
    As long as there is air moving in either direction it will cool the equipment. However if the cabinet enclosure is closed on three sides with the fans at the back, blowing air in won't be as efficient all pulling the air out.
  • Knucklehead
    110v 4inch it says "impeadance protected" on the box but no db rating.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • WilliamM2
    WilliamM2 Posts: 4,804
    If you need quiet fans, these are the quietest I have found:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835186121
    I run them off a 6v adapter, which makes them almost silent. I can't hear them at all with the door to the cabinet closed, with it open, I have to be less than a foot away to hear them.
  • Knucklehead
    cool!..no pun intended! thanks for the link.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • kneedragger37
    kneedragger37 Posts: 108
    Is there any rule of thumb for the CFM of the fan compared to the size of the cabinet?
    My cabinet is about 16 cubic feet (2ft x 2ft x 4ft) and has an AVR, XBOX 360, and Wii in it, among other equipment, and I leave the door open when using it because I'm worried about heat building up...
    And I saw someone asking about the db rating of the fan -- how low a rating should one look for?
  • WilliamM2
    I wouldn't worry about cfm, it doesn't take much to cool audio components, and high cfm generally means more noise. As far as db rating, there is no standard way of measuring, quite often a fan with a 19db rating will actually be louder than a fan with a 30db rating.
    I build a ton of computers every year, and have tried hundreds of different fans over the years. The ones I linked to above have been the quietest of them all. And as I noted, use a 6v wall wart to make them even quieter. If you have the room for bigger fans, they will push more air at lower RPM's, which will make less noise.
  • ntculenuff
    ntculenuff Posts: 1,146
    in car audio to cool amps in an enclosure we would have a fan pulling out hot air and one pushing air in that way you have a flow of air movement
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • leroyjr1
    WilliamM2 wrote: »
    Do you have a link for a 6v adapter?
  • BlueFox
    BlueFox Posts: 15,251
    For quiet, efficient, cooling operation run a drip irrigation line over the AVR to cool it. Works great.
    Seriously, if you find a quiet (inaudible at no music playing) let us know. My amp runs hot by design, and I was concerned last summer since it was getting really hot. I bought this "quiet" fan that I could hear during low passages in the music, so I had to get rid of it. I even moved my refrigerator into the garage to eliminate back ground noise. While I don't care if the amp is hot during the winter, I am concerned about this coming summer, since I now have 2 amps running in mono mode.
  • WilliamM2
    leroyjr1 wrote: »
    No, I have quite a few adapters around the house, and just used one of those. If I had to buy one, I would go for one of the adjustable 3v-12v models. That way you can adjust the speed to your needs. Radio shack has them, so does Walmart.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Personally I'd have them pulling the hot air out of the unit. As others have said, if they're in a tighter area, pulling cool air into the unit isn't going to be as affective.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • steveinaz
    steveinaz Posts: 19,545
    Agree with "evacuating" hot air versus blowing air on the component. Most components are designed for airflow to come from the sides or bottom, run across the heatsinks, and exit the top. Using a fan to suck the hot air out would be more efficient/effective IMO. Heatsinks are usually thicker at the bottom, and thin out as they get to the top. Blowing air in would force heat back down to the thicker bottom portion of the heatsink---counter-intuative.
  • WilliamM2
    Whether they blow in or draw out really depends on the cabinet. Most cabinets have open areas behind the components, so that you can get to the connections. In that type of cabinet, it won't draw air through the cabinet at all, it will just draw air from directly below the fan, and spit it back out.
    On my cabinet, having the fans draw out didn't lower the temps at all. So I have one blowing on the amps, and one blowing on the pre-pro. Everything remains cool to the touch.
    If you set the fans on top of the AVR, I would agree that drawing air out would be best, but keep in mind that if it's a closed cabinet, that heat is just staying in the cabinet.
  • mmadden28
    mmadden28 Posts: 4,283
    steveinaz wrote: »
    +1 on hot air evacuation, in addition to other similar comments.
    Hot air rises, so its logical to expel the hot air out the top.
    While I haven't installed my fans yet (right now they are just placed in the cabinet expelling), my plan is to take cool air in at the bottom, and expel it out the top. I am going to ensure that the CFMs of each are equal. My cabinet is a sealed type, really no vent holes, so I plan to cut holes and mount the fans as well as use an air duct register filter to ensure that I don't intake any dust.
    If I were only dealing with one fan (in a more open rack design) I'd use a temp controlled fan that varies its speed based on a temp sensor. This helps ensure that the fan is quietest when it is not relaly needed, but will speed up as it gets too hot. In my case so far I have not heard the fan over the sound of my DVR.
    ____________________
    Pool: Atrium 60's/45's
  • leroyjr1
    mmadden28 wrote: »
    What kind of fans are you running?
  • noscivic
    noscivic Posts: 15
    acsubie wrote: »
    I am curious about doing the same, but not sure on how to go about supplying power to the fan. Do you have an standard outlet plug connected to fan and the plugged into the power outlet on the back of the reciever, so when the reciever is turned on the fan is turned on, as well? Or is there a better, different way to go about it. Im new at this thing:o
    Thanks,
    Gary
  • noscivic
    noscivic Posts: 15
    acsubie wrote: »
    I am curious about doing the same, but not sure how to go about supplying power to the fan. Do you have a standard outlet plug connected to fan and the fan plugged into the power outlet on the back of the reciever? That way the fan is turned on with the reciever? Or is there a better, different way to go about it. Im new at this thing:o
    Thanks,
    Gary
  • Ender
    Ender Posts: 603
    WilliamM2 wrote: »
    QFT. As a person who loves building computers and is obsessed with airflow, I would have to agree that it depends on how your cabinet and receiver was built. It is better to have cool air to flow in due to air's excellent heat conductivity than it is to suck out hot air.
    Also, most often, despite dust concerns, it is better to blow air in as it causes natural air pressures to have an outward air flow. So, if you were using one fan and had at least two holes for air flow, you would want one fan to blow in while the air leaks out the other hole. You're basically continuously pouring in clean water into a murky pot and causing the murky water to flood and leave the pot.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • avhomedesigns
    avhomedesigns Posts: 29
  • cdn5003
    cdn5003 Posts: 144
    I have this Thermaltake fan on top of my 706 and it does a nice job. It is very quiet and has a speed adjustment knob. I have it running constantly on the lowest possible speed and it stays cool.
    http://www.amazon.com/Thermaltake-Mobile-Fan-External-Cooling/dp/B00080G0BK/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1235081356&sr=8-1
    HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
    2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2
  • BlueFox
    cdn5003 wrote: »
    Not all equipment has a USB port.
