Listening Positions . . .
SolidSqual
SolidSqual Posts: 5,218
edited February 2009 in The Clubhouse
I've discovered my CD of Eva Cassidy live sounds best when I have some Kettle One in my right hand, my left foot up under my right thigh in a half indian style position and an open State and Local Government Law Text balanced on my left knee. This half buddha position produces similar results with Nora Jones Live in Austin on LP, but I think the angle of my left knee coupled with the hard surface of the text book over-accents the midrange treble a bit. I've compensated for this quandary by straightening my legs out and sitting back on my couch in a full plank position. To really tweak this position out, I am balancing a Heineken on my belly applying the same theories employed by the geniuses who made the Elemental Voice Hi-Finator.
Rock on!
Post edited by SolidSqual on
  • beardog03
    beardog03 Posts: 5,550
    must be the book !
    try different authors and see what happens
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • BlueFox
    BlueFox Posts: 15,251
    Being left-handed, I have found that, generally speaking, everything good sounds better with either a micro-brew, or a glass of wine, in my left hand. Of course, this is also coupled with a recliner, and the foot rest elevated, in the music sweet spot.
  • Face
    Face Posts: 14,340
    I heard with those speakers that if you lift your leg to release some air, you're already out of the sweet spot, can you confirm this? :D
  • Early B.
    Early B. Posts: 7,900
    How sweet is your sweet seat?
    I sat off axis last week for the first time in years and I was shocked at how good it sounded. Of course, sitting a few feet off axis didn't sound precisely the same as the sweet spot; however, it had the same head bobbing effect, and that's all that matters.
    "God grooves with tubes."
  • phipiper10
    phipiper10 Posts: 955
    I can confirm the Kettle One provides improved musicality and just more enjoyment overall. I find a laptop can also provide subtle improvements. Of course running on batteries to reduce any interference.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
    treitz3 Posts: 19,188
    Amen.
  • dorokusai
    dorokusai Posts: 25,577
    I listen while standing on my head....and AMEN.
  • I-SIG
    I-SIG Posts: 2,243
    What about doggie style? :confused:
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • SolidSqual
    Early B. wrote: »
    My speakers sound pretty good off axis, but seriously the mesmerizing 3d effects somehow possible with stereo is only available when I am dead nuts center and have my speakers and furniture arranged perfectly.
  • markmarc
    markmarc Posts: 2,309
    Early B. wrote: »
    One thing I've rediscovered is how good many speakers sound without toe-in. The off-axis experience is much better IMHO than when the speakers are toed-in. Some speakers, such as Totems are designed to fire straight-ahead.
    I admit to being a bit biased about the concept that speakers should still sound good (not perfect) when off axis by a fair amount. To me it's a nod to real world acoustics, where many of us have to share listening space with other decor and uses.
    Former Staff Member TONEAudio
    2 Ch. System
