LSi15 speakers with RMs
Would the LSi15s blend OK with the RM302 as center or with RM30 as surrounds?
Tony
Tony
Post edited by alphaone on
Simple answer is, No. Totally different animals all together. At least get the LSi center and you could get by with RM30's for surround duty for time being. Your main concern is going to be timbre matching the front stage in HT, the three front main speakers.
Is there a bid difference in sound quality? I getss I want to know isf it is worth the cost? I have the 505 sub with the RMs.
Thanks -
Yes, there is a dramatic difference between those in sound characteristics and quality.
What do you mean worth the cost, to purchase an LSiC? Yes, it's worth the cost it that aspect. It all depends on what you are trying to achieve, if sound quality and the importance of timbre matching the front stage for HT, then definetely without a question, YES.
