computer question from a Dummie
sda2mike
i changed the password on windows and of course i forgot it:rolleyes:....what do i do now???
thanks
mike
thanks
mike
Post edited by sda2mike on
You didn't say which Windows OS you are running, but here is a link specifically for XP: http://support.microsoft.com/kb/321305
It's all the same though, there really is no way to log on without the password or a backup disc containing it. And think about it, would you want an easy hack, perhaps for a thief to use so he could easily open up your computer and see whatever it is you thought was worth protecting?
You'll probably have to reinstall your Windows OS from the original disc. This will blank out the password file so you can reassign once the reinstall is complete.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
hi
There is a program called ERD Commander which will help you with this problem...First you will need to get it by downloading it from somewhere. I have the program and can transfer it to you online. If you come into Yahoo Chat ( computers lobby 3), will get the program to you. I have the same nicname (renowilliams), in yahoo as well."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
Try bashing your head against the desk, might help jog your memory.If you will it, dude, it is no dream.
If you're running windows XP, it is likely that your administrator password isn't set. Reboot your computer and keep on hitting F8 while it's booting until a menu pops up and offers you the option to load windows up in 'Safe Mode'.
After Windows boots up to the login screen, choose Administrator. Wait for windows to boot up. Goto the start menu and right click on 'My Computer' and goto Manage
from there, you should see an option on the left indicating users. Click on it and you should see your user name in the main window. Right click on it and select 'Set Password' and change your password.
Reboot and try not to forget it againLovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
You can install Windows without setting an administrator password?
Talk about a security hole.If you will it, dude, it is no dream. -
bobman1235 wrote: »You can install Windows without setting an administrator password?
Yeah, it's pretty bad. Windows has never been known for its security. One of the many reasons I use linux.Lovin that music year after year.
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
i tried this....computer is still looking for a pasword -
got it! thanks everybody!
ok, search google for a program called ophcrack,download and burn bootable image and run it. it will find simple passwords
