CSiA4 Mod
curved
I've decided after switching from CSi5 to the A4 due to space restrictions, that I really miss my 5. Since the 5 can't be used, I'm going to do a cap mod. I'm limited to time since my new job which is fine because it only has 3:
.47uF
10uF
27uF
.47uF
10uF
27uF
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
Pre - Nak CA-5
BR - LG BD390
Well, I just order some Dayton Precision 1% Metallized Polypropylene Capacitors. I'll keep you all updated when they get installed.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
**Dayton and Sonicap Caps with Mills Resistors** -
Did you order enough for me?
Pre - Nak CA-5
BR - LG BD390
Keep us updated. Sounds like a nice cheap mod that should make a big difference.
Just picked up some AQ 14awg for the runs inside.
FYI - Any of you in the Milwaukee area might want to visit Flanner's. They have some Type8 20ft run for $100. Also have Type4 20 ft run for $40. I almost pulled the trigger on some type8'sLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Dang curve why you tell me that. On my way now. -
I'll be interested to see how it works out for you. To my knowledge, the only modern Polks that are being modded are the LSis, so I'm excited to here your review. You could be opening up a whole can of worms...
OMG!! That's all I can say. Outstanding value mod here.
First 5 minutes of listening:
Much much bigger sound!! Voices seem to be much clearer. The other thing I noticed was the center gain was a bit too much - had to back off on it a little. Much better match for the RTi8's. Before it seemed way too thin compared to the CSi5.
I'll give you all more feedback when they burn in a bit.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Time to do the 8's next. Was it fairly easy to do?
It depends who you ask.....:D
It really wasn't bad.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Pre - Nak CA-5
BR - LG BD390
I'll be ordering them when I mod my 8's since they are CHEAP!! I also might replace that dayton .47 with something higher quality - Sonic Cap, Aeon, etc.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
I may sound stupid:o When you say you mod the caps do you replace them exactly with the same values of capacitance and voltage or do you consider any other calculations please clarify.OMG!! That's all I can say. Outstanding value mod here.
I'll give you all more feedback when they burn in a bit. -
Same capacitance. Voltage will be higher with aftermarket but don't worry about that.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Update...I just got the 545II which will be powering the center. I'll let you know how the center sounds with some good clean power.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
I can't find a schematic, but the .47uf cap may not be needed at all. A value that small is generally used for a bypass cap. If you have the time and energy, you should try it with and without the .47uf in place. And while you're in there, I would also recommend replacing the resistors with Mills."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I think I will try taking that out...
Zingo also suggested that so I think I'll swap those out soon....especially since they're so cheap.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
is that deal at Flanners still going on?" would anyone be interested in helping me out by picking by the type 4s and shipping....pretty please:) -
I'll be out that way this weekend I'll check for you. -
you are the man..def. keep me posted -
The ones they had there were used. They had both the type 4 and type 8 in twenty feet. I thought they were going to be new for that price on sale. If you want me to get you the used/demo pair let me know. -
Curved, I'm a novice in this. If you have some time, do u mind sharing a step by step direction, including the parts that I need to buy? Appreciate your help..
Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07, logitech 880
Def Tech Mythos ST
Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
Bed Room: Pioneer Elite VSX-52 , Monitor 50
Storage-RTi8,CSi5,PSW505,Monitor50 -
Hooked up the 545 to it and it sounds AMAZING!! Bass is 10x better now!! It just doesn't seem as bright now either. Next mod will be resistors.....I'll post some more pics and give a better write up when I do the resistor mod.
Pre - Nak CA-5
BR - LG BD390
**UPDATE**
Ordered the following:
Sonic Cap .22uF (2 in each RTi8) and .47uF (replacing in A4) caps.
All Mills resistors
Dayton Caps for the rest of the 8's to match the A4
Pre - Nak CA-5
BR - LG BD390
x2
I would like to try some mods on my RTi 10's. Does anyone knows what could be upgrated?HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
Update:
Replaced the .47 Dayton with a .47 Sonic Cap. See the SIZE difference!!! I also replaced the resistors with Mills resistors. Haven't had much time to evaluate it, but it's an improvement already.
Pre - Nak CA-5
BR - LG BD390
Yes, it's been two years... how is your CSIA4 doing?
i'm looking to get that speaker and mod it
or should i just go ahead with CSIA6? since the mod cost of materials are probably going to be pricey?TV.......................Samsung 46" LCD LN46A550
A/V Receiver.........Yamaha RX-V3900
Amplifier.............. Emotiva XPA-1 Gen 2 for fronts, XPA-3 Gen 2 for center and Surrounds.
BluRay Player.........Sony PS3
Fronts...................RTia9 (modded)
Center.............. ...CSiA6 (modded)
Surrounds.............Empty for now. But waiting for a Fxi A6 deal on polk ebay.
Rear Surrounds.... Deciding if front presence is the way to go instead.
Sub..................... SVS PB12-plus/2 -
It depends on if you have room for the 6. If you do I would get it and modd it as well.
AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II
