Question ??? on SACD
dee1949
dee1949 Posts: 1,425
edited February 2009 in 2 Channel Audio
....does the laser read SACDs in a Sony DV-45A player or does the internal DAC have something to do with it. Want to KNOW if it is better to send audio out to MSB Link III dac or use the internal dac's of Sony.
Post edited by dee1949 on
  • TNRabbit
    TNRabbit Posts: 2,168
    As far as I know, there are NO outboard DACs that read SACD.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • unc2701
    unc2701 Posts: 3,587
    SACD uses DSD. There are a few DSD Dac's but your MSB is probably not one of them.
    Backburner:Krell KAV-300i
  • steveinaz
    steveinaz Posts: 19,545
    The MSB is PCM only.
  • Systems
    Systems Posts: 14,872
    dee1949 wrote: »
    The laser reads it,then it gets sent to a DSD decoder IC then to the internal DAC.HummDV-45A isn't that a Pioneer model#?The only way DSD data can be sent to an external DAC is via HDMI.It cannot be done with coax or toslink.
    Testing
    Testing
    Testing
  • dee1949
    ....Thank you Guys for reply. Yes, it is a Pioneer deck. Nice to know. The SACD player is in a separate HT system comprised of cast offs.
    Denon AVR-882 - receiver
    Pioneer DV-45A - SACD/DVD player
    DCM - QES's - front spkrs (1979 vintage)
    Definitive Tech c100 - center
    Definitive Tech Prosub 100 -sub
    Paradigm something surrounds
    ...Dark Side of the Moon, the second cut with the "Bells" and chimes.....still blows me away!!!!!!
