What surrounds and placement?
pablo_rodz
pablo_rodz Posts: 331
edited February 2009 in Speakers
Hi All!
I want to upgrade my surrounds... I currently have some old bose that were given to me. I was looking for any RTi bookshelves, but now I started looking at the FXi line. My set-up is listed on my signature. My main question is... Can I place FXi A4 or A6's on the rear wall or should I just place RTi bookshelves on stands to the sides of the couch? What would be the best option?
Layout of the room... It's an open format conected to the kitchen and dinning room...
Thanks in advance...
HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
Post edited by pablo_rodz on
  • pablo_rodz
    No opinions??
    Is it ok to have the FXi on the wall behind the couch and to the sides? Or is it better to have the RTi Bookshelves on stands at the sides of the couch?
    HT:
    Living Room:
  • Conradicles
    Conradicles Posts: 6,419
    In a typical 5.1 set-up, your surrounds should be on the side walls and a few feet above ear level when you are sitting down.
    For 7.1 you just add the surrounds behind your seating.
    I have FXi3's and like them. You could put them on the back wall and set them to bi-pole, and see how you like them. You have a tricky room.
    Ever thought about changing the room around?
    I had my living room the same for years thinking there was no better way, but when I finally ran all of my wires under the house, my new configuration is way better.
    By the way, nice system you got. Enjoy!
  • vijayl
    vijayl Posts: 258
    Assuming you have very little room at the back, I would go with RTi's on the sides to make it 5.1
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
  • pablo_rodz
    vijayl wrote: »
    That's what I thought too, but how would the FXi wor on the sides, on stands?
    I don't have side walls, but I have the speakers on stands on the side and above ear level, What would be a better option RTi's or FXi's on stands at the sides of the listening area?
    I don't have room for a propper 7.1
    I'm leaning towards the FXi's I could mount them on the wall to the sides and ablove ear level or on stands at the sides and above ear level... I wonder what would work better... The couch is against the back wall
    I have, but I have VERY limited options due to the size of the couch as placement of the fireplace....
    Thanks, slowly upgrading.. it's an addictive hobby..
    HT:
    Living Room:
  • pablo_rodz
    Well I got a great deal on a set of FXi A4 from Polk Audio Direct... Lets see how that goes...
    I will try them on stand at the side of the couch, and on the wall.
    Thanks to all that shared their .02 cents.
    HT:
    Living Room:
