7.1 speaker question. About rear sizes?
Vagrant Pistol
Vagrant Pistol Posts: 15
edited February 2009 in Speakers
I just got Polk Audio Rti A3's for my surrounds. I would like to do 7.1, but I don't know if I should get another pair of RTi A3's (they would be my sides) or a pair of slightly smaller RTi A1's (for my backs). I'm contemplating on this cause I don't know if it would mess up my soundstage if they were smaller. They are also cheaper in price.
-Sharp 46" (64U series)
-Denon AVR988
-RTi A7, CSI A6, RTi A3
-SVS SB12 plus
Post edited by Vagrant Pistol on
  • kneedragger37
    kneedragger37 Posts: 108
    I've never had a 7.1 system myself, but I can tell you that the ideal situation for any surround system is to have as many of your speakers identical as possible. That being said, most people on the forums (at least the posts I've read) think the A1's and A3's blend together well, so if cost is your number one priority, you'll probably be fine with the A1's.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    What are you using for your center and front channels?
    You'd be fine using both the A3's and A1's as surround channels though. The A3's are the better speaker, and thus would likely be the better choice...but of course you have to work within your budget. The A1's would work just fine.
    Make sure you have room to properly place all the speakers though. An improperly placed 7.1 setup is going to sound worse than a properly placed 5.1 setup.
    Have you looked into the FXi bipole/dipole speakers? A lot of people prefer those for surround channels. They might be a little bit out of your price range though.
    By the way, welcome to Club Polk.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Vagrant Pistol
    Thanks!
    I'm using RTi A7 for fronts and CSi A 6 for center. than my RTi A3's for backs. I never really read much about FXi bipole/dipole speakers. I know its a matter of taste for those types of speakers and they should be heard. I'll stick to my bookshelves.
    -Denon AVR988
    -SVS SB12 plus
  • comfortablycurt
    Thanks!
    Yeah...I feel the same. I know that I should probably check out the dipoles...but I prefer the looks of the bookshelves, so that's what I'm going with myself. Personally I somewhat prefer the sound of direct firing speakers to the dipole config's. anyway.
    That sounds like a nice system you've got going there. What are you driving it all with?
  • dorokusai
    dorokusai Posts: 25,576
    RTiA1 or FXiA4.
  • Mike21
    Mike21 Posts: 252
    Currently, there are few Blu Ray Discs produced in 7.1. The ones I have played did not have a lot of information coming out of the rear channels - much more out of the sides. So, IMHO, until 7.1 becomes prolific and the rear channels get more sound, you should be fine with the smaller speakers in the rear. That's what I have.:)
    Mike21
    avr: Onkyo 805
    Fronts: Polk M50s
    Center: Polk CS2
    Sides: Polk M40s
    Rear: B&W LM1s
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
    Toolfan66 Posts: 18,064
    I had bookshelfs for my surrounds,and i can say the Bipole/Dipole is the way to go for your surrounds.but this is just my personal opinon.i say if you already have a set of the A3's then i would just add another set of them.
  • Vagrant Pistol
    I have a Denon AVR988, but I decided this week to buy an amp for my front stage. I'm looking into the Emotiva XPA-3. Currently they are sold out, but I spoke to them and they said they will have them in about a month and a half. I know my Denon does a decent job, but I know these speakers can sound a lot better than they do with an amp.;)
    -Denon AVR988
    -SVS SB12 plus
  • Vagrant Pistol
    Mike21 wrote: »
    Mike21
    avr: Onkyo 805
    Fronts: Polk M50s
    Center: Polk CS2
    Sides: Polk M40s
    Rear: B&W LM1s
    Yeah, That's been on my mind. Maybe I should just wait than. I'll just put the money towards my amp and HDMI switch box.
    -Denon AVR988
    -SVS SB12 plus
