speakers crackling after running new wire?
bevo
My speakers are now crackling after switching to 14 gauge wire. I was using the wire that came in my old sony all in one. I actually never had any problems at all with it. I bought some 14g phillips wire from walmart, and now my speakers are acting kind of weird.
I know that walmart is probably not the best place to buy anything for a home theater, but speaker wire should work no matter where you get it.
What could I have done to make my speakers crackle like they are? It sounds like a short somewhere, but I can't find one.
If one of the wires have a bad connection, would it make all of the speakers make this noise, or would it just be the one speaker with the bad wire?
Here's another question while I'm thinking of it.
I have a dennon 1909, and have been noticing that my cable every so often goes out for 2 or 3 seconds. Sometimes it's just sound, others it's video, sometimes it's both. I have my cable box hooked up hdmi. It doesn't seem to do it with the ps3, and has only done it once with the 360.
Is this something that happens occasionally, when running everything through a receiver? Or should I take the receiver in for service?
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Post edited by bevo on
Have you physically handled all the cable from end to end to listen for the crackling? Or tried (carefully) moving the receiver to see if that causes the crackling?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Don't take offense, but are you sure you got the polarity right from the AVR to the speakers? Positive to positive and negative to negative?Coming Soon: The GregorPlex II Cinema
Sanyo PLV-Z2000 Projector
106" HDTV Formatted Electric-drop screen
50" Samsung PN50A450
Onkyo TX-SR876
Emotiva UPA-7 Amplifier
PlayStation3
Monster HTS 3600 mkII
*undetermined upconvert DVD player*
Polk LC265i Fronts
Polk LCiC Front Center
Polk LC80i Rears -
If your picture and sound is going out on it's own you may have a bum hdmi cable, however if it's just going out for a few seconds when switching channels or formats, then that's fine because hdmi is a complicated signal that sometimes takes your receiver a second to process.
Polk T90e's(m60)-mains
Polk CS2-center
Polk OWM3's-surrounds
Polk Micro Pro 1000-sub
PS3-blu-ray,gaming
Pioneer 43inch purevision plasma
Onkyo tx-sr606
MIT EXp 1
