freshwater aquarium, 10,000K metal halide?
SlowcarIX
SlowcarIX Posts: 887
edited February 2009 in The Clubhouse
anyone here uses a 10,000K lamp for freshwater tank? Is it too white/blue?
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
  • Pablo
    Pablo Posts: 723
    Unless you are keeping something specific (and hard to keep) in freshwater, you don't need to go crazy with lighting. You will save quite a few bucks if you go with a decent full spectrum flourescent blub and hood (on both electric and bulb cost). If you really like that light set up (which I wish I had), go salt.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Full spectrum flourescents here in all 3 tanks. I'm wanting to do some 'blue' in my cichlid tank though.
    tonyb Posts: 32,997
    Fish belong outdoors.....do like I did....build a pond,then you don't have to worry about all that crap.:p
  • SlowcarIX
    Keiko wrote: »
    I wouldn't recommend metal halide for a freshwater aquarium Abner. Those are better suited for saltwater reef systems with live rock, corals and invertebrates, such as anemones. It's an intense white light and gets really hot. You'll need fans for cooling them and also a chiller to keep the water temp down so you don't cook the livestock.
    i have been running MH since i started the tank...the last 2 bulbs were 6500K, want to try a new color range bulb
    its a 120gal open top tank and it looses ~3gals water everyweek
    there is only 1 species...started with i think was 8 and they multiply like rabbits...its up to 100+++ now :D
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    Pablo wrote: »
    i started out in the deep end with reef...did well. then moved to freshwater plant...with congo tetras, cardinal tetras and amano shrimps...
    got lazy when i moved to austin, started a 1 type fish tank :D
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    RuSsMaN wrote: »
    VHO tubes?
    blue like actinic 420nm light?
    what cichlids do you have?
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    tonyb wrote: »
    lol
    what do you have in there?
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    Keiko wrote: »
    Well, if that's working for ya cool. I assumed metal halide would be to hot for fw. I got a 90gal. mini reef in my dining room. It's become the aquarium of death, where only the strong survive. I haven't been giving it the attention that it needs lately. :o
    its hot and its bright. i like the shimmering effect from the light going thru surface ripples.
    i havent changed water in the tank for 4 months, just topping a few gallons a week...the rapid algae growth uses all the nutrients like nitrates/phosphates and i just harvest them everyweek. :eek:
    my 7.(1x4) HT setup
    Buttkicker
  • Willow
    Willow Posts: 11,056
    tonyb wrote: »
    right until November when I can have frozen fish sticks ;)
  • kitkat
    kitkat Posts: 7
    The truth is you do not need MH, reef req a MH because it reproduce natural Sun light, but what you would want would be a 14,000k mh, best of both worlds
  • SlowcarIX
    i had the ballast and reflector from when i had a planted tank. so rather than get a new setup, i just used what i had...
    14000K might be a bit too blue...
    i got a 10000K ushio bulb coming from dr forster /smith
    my 7.(1x4) HT setup
    Buttkicker
  • BIZILL
    BIZILL Posts: 5,432
    if you do this, before and after pics would be appreciated.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • RuSsMaN
    SlowcarIX wrote: »
    VHO tubes?
    I don't know, you tell me what I can add easily. My main tank is a little 55gal, and I need to find a local deal on something bigger. Right now, an assortment of Africans: Cynotilapia, Labidochromis, Melanochromis, Nimbochromis, Paralabidochromis, etc. Also have a big pictus cat in there, along with a pair of bala sharks and a goofy tinfoil barb. Oh, and a handful of giant danios that keep the top of the tank moving.
    I really have been wanting to do a South American tank, but I've grown so fond of the African temperment and personalities. Aggressive, but not overly so.
    Bad pics, just snapped a couple.
    Cheers,
    Russ
  • dorokusai
    dorokusai Posts: 25,577
    My FW tank is like watching an epsiode of Survivor.
  • SlowcarIX
    BIZILL wrote: »
    bulb should be here today - will take pics.
    the 2 pics above is taken under 6500K MH
    my guess is the higher kelvin light will have less reds/yellows...:)
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    RuSsMaN wrote: »
    Cheers,
    Russ
    you should be able to get a drop in actinic blue tube...since the actinics emit light centered at 420nm, you will need another full spectrum tube for the longer spectrum light (red/yellows)
    very nice mix of species living in harmony :D
    they always rearranging the gravel?
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    dorokusai wrote: »
    lets see some pics :p
    my 7.(1x4) HT setup
    Buttkicker
  • vlam
    vlam Posts: 282
    Would love to see pic of the 10K light. I too use four 6500K CF but thinking of replacing 2 with 10K.
    Wow.. I wish I could say that for the past 4 days. I have to change at least 30% of my water every other day.
    Main Gear
    Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7.
  • doggie750
    doggie750 Posts: 1,160
    You should try SALTWATER.....Reef set up to step it up a notch.....
    YOU wont regret it.....
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • CaligulaPolk
    CaligulaPolk Posts: 1,650
    doggie750 wrote: »
    You will need at least 2,500 dollars to "START" reef tank...
    Live rocks are not cheap and need to be 2x heavier than size of the tank. (Eg: 55 gallon tank, 110 lbs live rock, fiji is the best looking rock)
    Then there are lighting, filters,..... sums up way too much $$ but worth it at the end
    I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
    My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
  • 66chevyIISS
    66chevyIISS Posts: 857
    yeah until something dies and wipes out the entire tank and you have to start all over again haha.
    I've been close to doing saltwater many times, but haven't pulled the trigger yet. My tank would be very easy to convert, but I don't think I can give it the attention to detail it will require.
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
  • CaligulaPolk
    wont killing anything in water if you do slow process, not put too many fish at once. Saltwater is about patience ! :D
  • SlowcarIX
    you can go other alternatives besides live rocks like a phenum system - that does the same job of denitrification. or the berlin method...big **** protein skimmer to remove any material before they get a chance to breakdown...
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    an efficient protein skimmer is a must for salt...increases the buffer zone for mistakes
    i like the powered tunze ones
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    top is the used coralife 6500K bulb
    bttom is the new ushio 10000K bulb
    my 7.(1x4) HT setup
    Buttkicker
  • CaligulaPolk
    CPR skimmer worked great for my old setup! I still have it in storage :D wanting go back into SW hobby. Wife says not now, later when we are finished with everything needed be done. I think i will go larger next time. 4 x 125 gallon tanks (1 on each wall), its my dream room with spa tub in it.
    two old navy diver suit standing by the door with white / navy blue stripes wall creamic tiles all over.
  • BIZILL
    BIZILL Posts: 5,432
    HEY RUSSMAN, you outta try pool filter sand as a substrate vs the pebble. cichlids love to dig, which will collapse stacked rock if you don't set it up right, but it's a joy to watch them. they grab a mouthful and swim around releasing it and when it drops to the bottom it's looks like it's snowing. makes me also think of a snowglobe.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • SlowcarIX
    the 10,000K lamp makes the tank looks cold...sterile..on well, will change back to 6500K in 12 months time.
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    BIZILL wrote: »
    looks like the frontosa will make a meal out of the zebra :D
    my 7.(1x4) HT setup
    Buttkicker
  • vlam
    vlam Posts: 282
    BIZILL,
    That's a nice 155gal bow front you got there. I also agree with using pool filter sand, much cheaper than gravel.
    Main Gear
