Need help choosing a replacement
Fuzion64
Fuzion64 Posts: 2
edited February 2009 in Speakers
Looking for an equivalent replacement.
Hello, I owned a PSW50 until the speaker cone blew on it last week during normal use. Now I need a replacement since I have no bass. Please tell me what polk offers that would be a good replacement.
When I bought the PSW50 I got it for $75.00 at a local pawn shop, no manual and no specs so I am not even sure what kind of new subwoofer I need to buy to get the same amount of bass on a new subwoofer.
My setup was as follows:
4 Satellite speakers and 1 center channel from J&R Electronics Samsung Z410T satellites/center $20.00
Yamaha 6130 500w 5.1 channel a/v reciever -$200.00 (Local Radio Shack)
Polk Audio PSW-50 subwoofer $75.00 (Local Pawn Shop)
Not bad for less than $300.00
The subwoofer is down for good, so now I need to buy a replacement. Please tell me what is recommended I had been looking at a PSW-110 available thru amazon for , but I am not sure how it compares to what I was using. No specs came with my old subwoofer.
Would you recommend this one?
http://www.amazon.com/Polk-Audio-10-Inch-Monitor-Subwoofer/dp/B0002KVQBA/ref=pd_cp_e_2?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B0013EQ1K0&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=115CYA0EDKXK1QHK5NBC
Post edited by Fuzion64 on
  • donedroolin
    donedroolin Posts: 225
    Hey Fuzion64, WELCOME to club polk. What were you looking at spending on a new replacement sub. Also check the FOR Sale section here on Polk.
    TV- 52 inch LCD SONY BRAVIA XBR6
    TV- 42 inch PLASMA HITACHI ULTRA VISION
    AMP- PARASOUND HALO A-51
    CONTROLLER- PARASOUND HALO C-2
    FRONT SPEAKERS- LSi15's and LSiC
    REAR SPEAKERS- LSi7's
    SUBWOOFER- VELODYNE DD15
    BLU RAY- LG SUPER BLU BH200
    BLU RAY- SONY BDPS350
    GAME SYSTEM- NINTENDO Wii
    MONSTER POWER CONDITIONER
    WIRES- AUDIO QUEST and MONSTER
  • Fuzion64
    Fuzion64 Posts: 2
    I would say between $100.00-$250.00 would be safe.
    I could probably go $300.00 if I really had too, but that would be my absolute maximium.
    Edit: 02-09-09
    Just ordered a polk audio PSW-10 for $116.99 thru amazon.
    I just need to know how it will perform when compared to my psw-50.
  • donedroolin
    Well I am not familar with the PSW50. I have read on these forums that Subwoofers are Polks weak side. The PSW110 looks OK. I woul personally look into something from VELODYNE like the VX-10. I am partial to velodyne, but you also can't go wrong with a Velodyne product. Check them out on line. Also look at SVS and HSU.
  • donedroolin
    Fuzion64, Check out Ebay and also watch Craigslist.
