Finding out if the speaker i have is blown
Larryjepson
I recently bought a center channel speaker online and i have a question the left speaker is louder than the right is it possiable the speakers blown on the right side or am i just over reacting im not sure how to figure this out anybody has ideas or suggestions please let me know thanks.
Post edited by Larryjepson on
What model speaker is it?
I know some of the Polk center channels had a passive radiator in them, which would cause one of them to be louder than the other, simply by it's design. I'm guessing that's the case.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
the center channel speaker is a polk cs400
No passive radiator there. Possibly a disconnected wire?"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
disconnected wire where inside the center channel?
Hm...I don't believe that model has a passive radiator. It does, however, have a cascade tapered array. What that means is that the two 6.5" drivers are tuned to different frequencies. One driver is crossed at a lower frequency and is essentially a bass driver. The other driver plays the upper midrange frequencies, which eliminates interference between the two drivers.
This could be contributing to the different volumes between the two drivers.
One thing you might try is removing each of the drivers, and connecting them one at a time directly to the speaker outs of your receiver. Play them at a very low volume for a few seconds. If each of them appears to be at the same volume...then neither one should be blown.The nirvana inducer-
Good advice CC. Check it out and report back Larry"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
comfortablycurt wrote: »Hm...I don't believe that model has a passive radiator. It does, however, have a cascade tapered array. What that means is that the two 6.5" drivers are tuned to different frequencies. One driver is crossed at a lower frequency and is essentially a bass driver. The other driver plays the upper midrange frequencies, which eliminates interference between the two drivers.
i agree with this... and it's good advice. if it's a cs400PolkFest 2012, who's going>?
See... right there's your problem. I think it's blown.
Slowly emerging from the 90's
Fronts: Polk LSi15's
Center: Polk CS350ls
Pre: Sony STRDA555ES
Amp: Rotel RMB-1075
Sub: Velodyne SPL-1000
TV: 46" Sharp Aquos LCD
Dust magnet: Sony PS3 -
Damn...I think that mid-woofer needs to be reconed or something...lol Tweeter isn't looking to healthy either for that matter...:pThe nirvana inducer-
Best way to figure out if it's blown? Listen to it. Does dialogue sound distorted or lacking when watching a movie? If you're just comparing right vs. left speaker output, then that's not enough......comment comment comment comment. bitchy.
That is a CS400i. It has blue cones.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
