Dolby PLIIX V.S. THX Ultra2 Cinema
wingnut4772
wingnut4772 Posts: 7,519
edited February 2009 in Electronics
For what it's worth I am digging the THX over the PLIIX. I find that it has a more sophisticated surround envelope. It doesn't call attention to itself and balances out the surrounds nicely. Every time I switched back to PLIIX it seemed more dynamic but I had a sense of ' that effect is in that surround. this effect is coming from the other etc...'
The THX Ultra 2 Cinema just gives me a nice, pleasing immersive experience. Mama likes.:D
Anyone else?
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
  • TheMARPATNinja7
    TheMARPATNinja7 Posts: 150
    What are you using this for, music I'm assuming?
  • wingnut4772
    Sacre Bleu!!! No. Movies. :D
    Music is stereo plain and simple.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • kuntasensei
    kuntasensei Posts: 3,263
    I can't stand what THX does to the surround steering. Yes, it gives a kind of generalized immersion... but it doesn't place sounds with the precision that DPL-IIx does. I get what you're saying about the differences though. That's why THX is easier to integrate, because you can be a little looser with placement, equalization and level.
    DPL-IIx takes a little more work to integrate for best results. One thing that really helped solidify my rear soundstage with DPL-IIx was tweaking the distance/delay settings using DVE's between-speaker tones. You can bump distance up and down and hear the speakers go in and out of phase, making it easier to find the best setting. Sometimes physical distance isn't necessarily the same as the best distance for acoustics.
    It's really just personal preference though. But for me, the precise placement of DPL-IIx works really well with games on the Xbox 360 and adds a more directional experience to movies. THX, in my opinion, makes my 7.1 system sound like it did when I only had 5.1, so I don't use it.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • TheMARPATNinja7
    Is THX actual Digital 5.1 surround or is it modified 5.1 like PL?
    And I use PLIIX for music and it really adds a nice effect. The sound is clearer than using a 5 or 7ch stereo. You still get 95% of the music in the front three speakers but the other 5% is actually pretty cool. I like having those highs racing around my head.
  • TomBergamini
    TomBergamini Posts: 31
    I hear no difference between them
  • wingnut4772
    Maybe it's because I have to have my surrounds on stands and can't wall mount them in my current house. PLIIX might sound less localized If I had wall reflection to play with my bipoles. As far as placement and calibration I am not new to this rodeo and they are not too bad.;)
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • TheMARPATNinja7
    Believe me give PL a shot, I have Prologic and "Panorma Mode." This boosts some of the highs in the surround speakers and I couldn't be more happier with the sound.
  • wingnut4772
    i have tried both and the THX just sounds more realistic in my room.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Lowell_M
    Lowell_M Posts: 1,660
    Are you all watching VHS or something? Why do you need processed surround sound rather than just DTS or Dolby Digital surround?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • SlowcarIX
    SlowcarIX Posts: 887
    is there a difference between Multich and THX cinema?
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • Lowell_M
    I still don't get it. Why use any processing? Dolby digital and DTS are already 6 discrete channels. Why screw with it?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • metal83
    metal83 Posts: 1,219
    a_mattison wrote: »
    I only use PLII when watching something on Directv that doesn't support DD (it will just kick to PLII automatically for me if DD isn't supported). Other than that, my receiver basically always says DD. Unless of course i'm watching a blu-ray movie, then i'll use which ever HD format the disc offers.
  • Marty913
    Marty913 Posts: 760
    a_mattison wrote: »
    Direct TV and/or cable channels as mentioned are not all DD plus there are some older movies on DVD that were not originally remastered into DD from the VHS versions. Most have been reissued now but if you still have the original version, you still have Dolby Surround (or worse).
    To answer the original question, I prefer the PL II Movie mode versus the THX but it's a close call. Music of course is 2-channel except for rare occasions (parties, working around the house) when 5-channel stero is OK.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • wingnut4772
    Isn't DD just 5.1? I use PLIIX to get the back two channels going.
    I read something today that said that Ultra2 was layered over PLIIX. IS that true? It doesn't seem so. I think THX Cinema is and I have been experimenting with that also.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Marty913
    Marty913 Posts: 760
    Yep, I have got to spend more time thinking about these questions before I answer. THX Ultra2 is the 7.1 extension of THX Ultra (5.1). If I remember correctly there was even a room size intention or spec. Something about Lucas wanting the original THX spec to sound more theater-like in rooms of 2000 cubic feet (Ultra) and the extended it to rooms over 3000 cubic feet (Ultra2). Something like that.
    Dolby Digital is 5.1, not 7.1. DD EX would be 7.1
    TT = Audio Technica
  • Lowell_M
    OH... I only have 5.1 which is why I've never paid attention to this subject. Thanks.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Marty913
    Marty913 Posts: 760
    It has occurred to me though that secretly they are all the same. Since THX of any kind is really a "certification" of compliance and Dolby PLII is the actual algorithm, is Ultra2 really a certification for a layered over PLII (EX). It's all Lucas the "certifier" and Dolby the "creator" so wouldn't one have to be based on the other?
    Is it possible that this is all a huge plot by decal manufacturers?
    TT = Audio Technica
  • cnjvh
    cnjvh Posts: 253
    THX as noted above is not a surround processing device, it is a certification standard. Engaging THX mode sets your amp to all the settings recommended by THX (speakers at small, xover at 80, cinemaEQ engaged, etc).
    Surround decoding and steering are handled by the pre-pro's DTS and DD functions.
    DD can be anything from 2.0 to 7.1. It is an encoding scheme that is not based on the number of channels.
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • Marty913
    Marty913 Posts: 760
    Probably not the definitive technical answer but a pretty good breakdown nonetheless.
    http://en.wikipedia.org/wiki/Surround_sound
    Personally, I'm waiting for Quadraphonic (the Sansui implementation) to come back.
    TT = Audio Technica
  • kuntasensei
    cnjvh wrote: »
    Nice explanation, but you're misunderstanding the terms here. There's THX Certification (i.e. Ultra and Select)... then there are THX listening modes (which use THX's Advanced Speaker Array technology to alter the content of the surround channels to attempt to recreate the differing studio environments). These modes are called THX Cinema (either Ultra Cinema or Select Cinema, depending on the unit's certification), THX Games, and THX Music. Each is designed to artificially recreate the mixing environments for each of those types of content.
    Yes, you're correct that choosing a THX listening mode usually sets the receiver or pre-pro to THX standard settings. However, the THX ASA modes ARE surround processing. In fact, they can be overlaid with DPL-IIx steering in some receivers and pre-pros, giving you the surround steering of DPL-IIx with the ambience and adaptive decorrelation of THX listening modes.
    That's part of the reason I don't like the THX modes. They actually alter the content of the surround channels slightly. Most receivers that I've heard tend to lend a more tinny echo sound when using THX modes, and it really stands out to me. DPL-IIx, on the other hand, is simply a steering method, and doesn't attempt to create sound that isn't already there. It merely says "that sound is 50% left surround, 50% right surround, so let's place it in the rear surrounds", etc.
    Equipment list:
    Emotiva XPA-3 amp
  • lakesailor
    lakesailor Posts: 319
    I am not a fan of PLIIX either. Fortunately if you are using an H/K product you can use Logic 7 instead. Logic 7 is one of the reasons why I still use H/K in my rec.room system. Developed by Lexicon; Logic 7 is night and day above PLIIX
  • kuntasensei
    I like Logic 7 a lot. However, it suffers from some of the same problems that DTS:Neo6 has, where there's some sharpness added to the surrounds that makes them sound kind of tinny with highs and with a very slight artificial echo. It's not nearly as bad as DTS:Neo6 though, and it is a bit more forgiving of proper setup than DPL-IIx is.
    I'd say Logic 7 and DPL-IIx are a toss-up for me. Both are superior to THX modes though, because they're not monkeying with the original content - just steering the sound based on the phase relationships and levels between channels.
    But y'know... all this crap is personal preference no matter what. Stick with what you like. ;)
    Equipment list:
    Emotiva XPA-3 amp
  • rdb2001
    rdb2001 Posts: 791
    Ok if you are using Dolby PLIIX or THX Ultra2 Cinema while watching your blu- rays, are you truly hearing the dolby truehd or dts master codecs. I am curious and wanted to know because the same question was asked to me and I couldnt answer it. Thanks
  • cnjvh
    cnjvh Posts: 253
    Nice explanation, but you're misunderstanding the terms here. There's THX Certification (i.e. Ultra and Select)... then there are THX listening modes (which use THX's Advanced Speaker Array technology to alter the content of the surround channels to attempt to recreate the differing studio environments)...
    Thanks for the added info...didn't know that part.
    --Stuff--
    AVR: Denon AVR-3805
    STB: Xfinity X1DVR
  • Marty913
    Marty913 Posts: 760
    rdb2001 wrote: »
    Can't answer it for absolute/positive but it would seem that if you are altering the steering and/or content mix then you would not be listening to the TrueHD or DTS Master steering and or content mix. Don't know how you could "re-author" something electronically and still have it be the same as the original.:confused:
    TT = Audio Technica
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Cut to final scene.......................
    after battling the forces of surround sound music our heroine stands over the limp body of the five eared devil lying on the ground, knife in hand she pulls it from the hilt as the body gives one last kick body and says...................That takes care of That, now somebody get me a Cheesburger...........
    Cut to Credits.......................
    RT1
  • lakesailor
    You are correct; on some signals I have noticed that as well. Mostly I prefer the front end of Logic 7 and that is likely why I have not noticed the issue with the rears (but you are right; it is there) Mostly what I dislike about PLIIX is the lack of front end performance. It is very blah in my books.
  • kuntasensei
    lakesailor wrote: »
    I don't like the default front sound in DPL-IIx Music, because I don't like the way the center channel works with music (though some of that is due to my center placement). Have you tried bumping Center Width to 4 or 5? That is what made mine really snap together, since I already had good stereo imaging from my mains.
    If you were talking about with 5.1/6.1 material, DPL-IIx doesn't change the front soundstage.
    Equipment list:
    Emotiva XPA-3 amp
