Dynamat
VR3
Well - R-Blox more like it...
I bought 100 sq ft of it...
I just R-Bloxd' my hood (dosnt sound as cool as dynamat)
Huge difference... Im going to slowly dynamat everything in my truck, doors, floor, dash, back wall, possibly will figure out how to take down the headliner (dealer) and apply some there
Just trying to reduce as much road noise as possible.
Post edited by VR3 on
Yup, makes a huge difference. You can never have too much Dynamat. If I had the money and time....and patience Id pull everything out of my car and Dynamat the entire interior.polkaudio sound quality competitor since 2005
RBlox is pretty cheap, 130 shipped for 100 sq ft and it was pretty easy to work with...
And that is basically my goal - dynamat everything. It made a huge difference in the hood - for sure.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You're going about it wrong if you're wanting to reduce road noise. While sound deadening mats have a slight by-product of reducing road noise, they were designed to keep things from rattling. The only reason why it reduces noises is because you're putting another lay of 'something', which could be replaced with 'anything', between you and the noise.
The best way to get rid of road noise is through noise barriers, not damping mats.
The bad thing is, they are wayyyy more expensive than regular mat. Here are some examples:
http://secondskinaudio.com/products/Acoustic-Thermal-Insulation.php
I will most likely apply that to the floor --- as that would solve alot of road noise -- but I cant see applying that to doors/ceiling/walls - etc
Looks a little messier
Thanks for the tip.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Cody is right that it wont do a whole bunch to quiet the ride but what it does is kill resonance. When you play your music or even drive down the road, the plastic trim pieces and sheet metal rattle, vibrate and even resonate. By layering everything with Dynamat you cut this down drastically so that any noises arent amplified so they seem quieter. It does wonders for your music because in a well dampened car the music feels more isolated from the car and it starts to feel less like youre in a car listening to music and more like youre sitting in a room listening to music.polkaudio sound quality competitor since 2005
I deadened one door today -- passenger rear door --- I dampened the crap out of it...
Everybit of exposed sheet metal on the door - is deadened, I deadened both sides of the panel where the speaker is mounted and I deadened the entire door skin itself -- multiple layers... particularly around where the speaker goes.
The door even shuts quieter than before -- but I sent the music to that door and then panned to the door on the driver side and the difference in rattling was significant... more than worth it...
I'll slowly do a door at a time and eventually will have them all done - hahaha... I guess that is how it works eh? Great investment so far!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
^^ yes.... reducing your noise floor will make your music "louder"
it's like talking in a quiet room as opposed to talking in a concert. you are still speaking at the same db level but because of the higher noise floor at the concert, you are barely heard.
you can snag sound proofing material at your local industrial supplies warehouse. it's still expensive but cheaper than shipping that stuff... sound proofing is heavy and expensive to ship.
