polk rm10 speakers
I just purchased this set Polk rm 10 and I need to know if anyone has mounted them on the ceiling..our house is prewired and there are four boxes with wires..I just would like to know if there is a mount that would hold these speakers and cover the opening in the:) ceiling.
Post edited by sdsolo on
If the wires come out of standard electical boxes there are these: http://www.btech-usa.com/bt34.htm#bt34ac1 . If not, look at the rest of B-tech's stuff. Or here: http://www.omnimount.com/consumer/Default.aspx
I have been dealing with a similar problem as of late. So I know where you are coming from.
Toshiba 62HMX85
Panasonic DMP-BD60
Xbox 360 with HD-DVD
Pioneer VSX-9130-TXH-K
Polk Audio CSiA6
Polk Audio RTi10's
Polk Audio RTi4's
Polk Audio RTi6's
Polk Audio PSW505 -
x2 on the B-tech mounts. B-tech makes some quality stuff. I have a pair of B-tech 77 bookshelf wall mounts, and couldn't be happier with them. I don't even use them anymore though because I have floorstanders now...The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
