Is this swap worth doing?
Long time viewer/reader, however this is my first post.
I currently have:
RTi8s for fronts
CSi3 center
RC60i rear surrounds
I am considering replacing the rears with TC60i or TC80i since they are timber matched with the fronts. Is this a worth while switch or should I leave it as it is. I will be upgrading my receiver to an Onkyo 706 if that makes a difference.
I currently have:
RTi8s for fronts
CSi3 center
Post edited by Allykahn on
That would be a very worthwhile swap, since, as you said, they're timbre matched to the fronts. That's an important aspect in a HT setup.
I say go for it.
By the way, welcome to Club Polk.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Thanks for the welcome. I really enjoy this forum.
Which should I get the TC60i or TC80i (a tad more costly)? -
What is the difference between the TC60i and the TC620i?
Frequency response, power handling, and most importantly you drop from the same 1" tweeter that's in your RTi fronts to a less expensive 3/4" tweeter.
