Cables to External Amp
asd1234
asd1234 Posts: 30
edited February 2009 in Electronics
My receiver has RCA pre-outs and the amp has both RCA and XLR inputs. What type of cable would work best. RCA to RCA or RCA to XLR? or does it even make a difference.
Post edited by asd1234 on
    Toolfan66 Posts: 18,055
    i have mine RCA to RCA, i think you would just be fine with that as well,but there might be someone here to help you out more on this.
  • Hawkeye
    Hawkeye Posts: 1,313
    RCA>RCA
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • cfrizz
    cfrizz Posts: 13,415
    RCA to RCA. Welcome to Club Polk ASD.
  • asd1234
    asd1234 Posts: 30
    order placed at blue jeans.
    Thanks guys
  • thuffman03
    thuffman03 Posts: 1,325
    Unless you are going long distances between you amp and pre I would go RCA. The XLR are better at long distances and can deal with RF interferance. Plus you don't say your receiver has XLR out's so this would be a mute point anyway.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    In your case sonically they would be exactly the same, however, RCA to RCA is going to cost less.
    RT1
  • TNRabbit
    TNRabbit Posts: 2,168
    It wouldn't even do any good unless you have XLR on both ends. RCA to XLR or XLR to RCA loses any balanced transfer.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
