Vintage Denon Receiver Specs.
  • timheath
    timheath Posts: 1
    edited June 2011
    the Denon dra-25 is no slouch, I got one brand new in 1987 along with polk 5jrs(blew them up years ago). I still have the denon and use it everyday., I have abused it, made it run 8 speakers one time it ran so hot the solder melted off the transitors(by the way the heat sink apparatus is oil cooled), I just put new solder on and it still runs today like it did when it was brand new! I have had many other amps come and die or get sold off, but this one wont quit. . My dra-25 is now in semi retirement used as a pre-amp so I only make it push about 1watt fed into my tube amp sound quality is pure and simple.
  • gdb
    gdb Posts: 6,012
    edited June 2011
    Gonna hafta call you the Punisher!
  • alexholeinone
    alexholeinone Posts: 17
    edited March 2012
    skrol wrote: »
    Mail sent
    Enjoy!
    Stan how are you. Just scored a DENON DRA 825RA today at Goodwill for $35.00 but missing the remote and the owners manual. As i read the post you might have the manual for it. Can i also ask if you can email me the manual, but if for any reason you can't its ok, just have to wing it for now. So far the unit is working, tried to use the pre-out to drive my Hafler XL600 with Polk SDA 2B's with Dual TT 1229Q with Dire Strait Sultan of swing and it sounded wonderful. Then i used the Denon Main with Hafler Iris Pre-Amp with same music, sounded good but the Bass is not as tight as my Hafler XL600, and the mid's and high's are just right. All in all i think it is a great buy.
    My email is "alexholeinone@gmail.com"
    Thank you,
    Alex
  • skrol
    skrol Posts: 3,499
    edited March 2012
    Sounds like a great buy. I don't have experience with the DRA-825RA but with the 825R and 835R. The 835R does improve in the bass department over the 825R.
    I plan to do the same thing using the 835R as a preamp and getting an Adcom or Carver or other for a main.
    I'll see what I can do about a manual.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jigbim
    jigbim Posts: 1
    edited October 2012
    I just stumbled upon this Denon DRA-825RA thread. I was lucky enough to have picked one up during college when I worked as a delivery/setup guy at a high-end audio store in Duluth, MN back in 1989-1990. Between about 1999 and 2008 I "retired" her to service as a dedicated tuner (I know - blasphemy!) in my whole house audio setup. I recently tried to fire her up as a standalone with my polk monitors, but alas - something happened in storage. The display lights are flickering, and no sound comes out at all. I know enough about electronics to get myself in trouble, and I'd love to take a stab at troubleshooting this before I try a "real" professional. Does anyone have a copy of that elusive 1025RA/825RA service manual? I keep coming up empty except for an old auction on ebay canada.
    By the way, I still use my Denon 5-disc CD changer daily, and recently found my old "universal" denon remote that is about the size of a kindle fire. Brings back some memories, I tell 'ya!
  • wmotch
    wmotch Posts: 1
    edited May 2013
    I have a Denon DRA-825R that I just got from a friend and I also have a Technics rack system with the SU-G91 amp and separate tuner - ST-K50 - the technics system has 5.1. Just bought a new pair of B&W speakers and trying to decide which system to hook up - currently not using surround sound in this room -just music - wondering if you know which would sound better and also if either system could be used to biamp the new speakers
  • skrol
    skrol Posts: 3,499
    edited May 2013
    I almost picked up an SU-G91 at a thrift store. It would immediately go to protect mode even with no speakers attached. Apparently this model is prone to overheating and frying the amp IC's. The fans also tend to go bad. I read reports that they sound good when they work. It is not true 5.1 but converts the 2-ch via Dolby ProLogic.
    I would tend to believe that the Denon would be the better bet.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Kraken
    Kraken Posts: 1
    I found this forum while researching a potential purchase of a Denon DRA-825ra or possibly a Luxman R-115.
    The 825ra is advertised as in un-used, pristine shape and it looks like it. It does not have any signs of wear and is very clean complete with AM loop and FM antennae, RC-125 remote, original box and packaging including dust sleeve. It does not have its manuals. The Denon comes with an DCM-555II cd changer in equal condition.
    The Luxman R-115 is used, no remote, no manual, no antennae, nor box. It is fully functional and has been recently serviced.
    In vintage stereo circles, the R-115 is highly regarded as "...among one of the best receivers" but the Denon has its fans, too.
    They are the same price. I can pick the Luxman up locally but the Denon will need to be shipped across the county adding that cost to the purchase.
    So which is the better receiver and which is the better buy?
    Great site by the way. Very interesting with good information.
