What is a predriver?Class A
phipiper10
I've not spent much time reviewing different amp classifications but have some understanding.
The B&K manual says:
operates class A predriver and AB high current MOSFET power
output stages.
What does the predriver do? Does this actually operate in class A for some brief period up to x watts or something before switching to AB?
My google search didn't yield much so maybe this is better known by some other name?
Thanks!
output stages.
Thanks!
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
phipiper10 wrote: »operates class A predriver and AB high current MOSFET power
output stages.
Thanks!
Most High Power High Current Amplifier has different several gain stages. The early gain stage / the 1st gain stage refers to as the pre-driving stage for the later gain stages. B&K said it uses Class A topology for the predriver stage and then the Class A signal from predriver stage is fed to the later gain stage which is Class AB topology. This allows purer signal transfer between 1st gain stage and later gain stage. I think it also known as Class A biased Class AB amp.
It does not necessary means that it operates in Class A for a first few watts and then switch to Class AB. I know some Parasound amps do that but not in every model. I don't know about B&K. You need to ask B&K with the specific model about it.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Thanks Mega that helps.Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
phipiper10 wrote: »What does the predriver do? Does this actually operate in class A for some brief period up to x watts or something before switching to AB?
An amp with an Class AB output stage will operate in Class A up to a certain power level determined by the actual amount of bias current ,then it switches to Class B at higher levels.Testing
Testing
Testing
