just received new rotel rmb 1095 but no sound
cembros
cembros Posts: 172
edited February 2009 in Electronics
ok so i just got my new amp today and i got it all hooked up, or so i thought, and to my dismay there is nooo sound. I have my speakers connected to the amp with banana plugs and then i have the amp connected to my receivers pre outs with rca cables. I am using some cheep rca cables from radio shack http://www.radioshack.com/product/index.jsp?productId=2289558 since i wont get my other cables in for a couple of days. My equipment is sony 3300es receiver, lsi15's lsic lsifx's. Please help, i was thinking that the problem could be that the rca cables cannot carry the load??
Post edited by cembros on
  • eclimax13
    eclimax13 Posts: 168
    turn off you 12 volt trigger toggle switch if your not using a trigger
    Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
    Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
    Bed Room: Panasonic TCP50x1, Samsung Bd c7500
    Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
  • cembros
    cembros Posts: 172
    eclimax13 wrote: »
    i could kiss you, but i wont, thought i got a dud
  • eclimax13
    i just hooked up my amp today...so you can guess how i knew that was your problem ;)
  • cembros
    cembros Posts: 172
    i was freaking out thinking i got a dud
  • cembros
    cembros Posts: 172
    ok i thought that had fixed the problem but the amp keeps shutting off, right now its sitting on my carpet untill i can get longer cables, could this be a problem. Im going to try and put a small peice of wood benith it
  • Hobbyguy
    Hobbyguy Posts: 317
    Congratulations I just got mine 2 days ago and it sounds soo much better than my yamaha receiver. I have cheap interconnects also and they make poor contact with the amp....the sound would fade in and out. I bent the rca pins alittle and the contact is much better and the sound doesnt fade out. I just ordered MIT interconnects.
  • cembros
    cembros Posts: 172
    ahhhh this is really driving me crazy, i put a slab of wood benith the amp, the amp will play for about a minute and then shut off, the led light on the amp stays on indicating that the unit is on but there is no sound
  • olilugo
    olilugo Posts: 405
    Cembros, I am looking at your amp and it looks very simple.
    I think what I would do is disconnect all cables from receiver to amp and the speaker cables from the amp to spearkers. then I will add one at the time. I think what the problem could be is that now that you have more power one of your speakers might be creating a short. hopefully this way you can identify what speaker might be having the problem.
    Also I would not rule out that your amp has a defect in one of the chanels.
    I hope this helps.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • megasat16
    megasat16 Posts: 3,521
    I have Rotel RMB 1095 myself in all black color. This amp has internal heatsinks that requires a lot of air circulations and ventilations. That's why the amp has a lot of air vent on the chassis on the top cover as well as on the bottom plate.
    It's best not to put it on the carpet by itself because air flow is very restricted if you put it on the carpet and the amp will go into protected mode (all lights red and no sound) after it gets warm.
    You need to check your amp to see it has the feet underneath it. All amp comes standard with the feet / cones underneath. If you see the feet underneath, you can put the amp on a slab of wood or on a proper amp stand. Do Not put this amp in the enclosed cabinet or shelves or on top of other components or anything on top of it. Anything that restricts a free air-flow is like a major NO NO for this amp normal operation. At least, that's what I found out mine. It'll run happily all day if you make sure a good air flow around it and underneath it unless yours a lemon. :(
    I hope you good luck and it's a nice sounding amp.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    heiney9 Posts: 25,547
    megasat16 wrote: »
    While this is good general advice...................there is no way that amp could get hot enough to shut down in a few minutes sitting on the carpet. But, get it off the carpet ASAP.
  • megasat16
    heiney9 wrote: »
    Yeah, H9. Shouldn't be like that but it does. I know mine does but it does that in about 5-10 minutes. But again, how soon it shuts down depends on how loud you really crank the amp up to on a carpet. I know mine is not a lemon but it gets hot VERY VERY VERY FAST. Nothing wrong with it. It's the way it's designed I guess. A lot of air vents underneath to sucks the air up and cool the heatsinks. My cat favorite amp. :eek:
    I put it on the small wooden cart with wheels underneath and the center of the cart is all wide open. That makes a very good ventilation and the amp runs cool and runs all day long.
    My single ended Class A amp has large external heat sinks and it's designed to run HOT. It runs about 200 watts idle and I can't touch the heat sinks for more than about 5 seconds. It takes about 10-15 mintues to start to heat up and about a hour to reach full operating temp.
    There is something else wrong with the OP's amp if it goes into protect mode so easily and quickly.
    I hope he gets it figured out..........because it sucks to get a new piece of gear and then find out there's a problem. Very frustrating
    GL
  • megasat16
    Yeah! I know it's very frustrating and happened to me with this bloody rotel model. I still keep it because it sounds very nice. But it's thermal protection circuit is designed in such way so it will trip when it gets hot very fast, I think. It's probably most usual problem with everyone's RMB-1095.
    The OP's amp might be half lemon and he can find out after running it in wide open space.
    Class A is very different from AB since it lost nearly half of the power during thermal dissipation and gets very hot. But you are rewarded for the loss with the blessings of almost 100% identical amplified output signal to the input. I'd say 200wpc is a damn good beefy Class A amp you own and what speakers you are driving with it?
    megasat16 wrote: »
    200 watts is what it draws at idle from the wall socket..........output is 30wpc @ 8R.
    I have modified SDA 1C's and it runs them with no issues :). I'm liking the heat during the winter..........but summer is going to be interesting. There is a thermal shut off at 170* F
  • megasat16
    heiney9 wrote: »
    Class A is an excellent space heater to double functions and a very good choice for an amplifier. I am sure you'll be very happy with SDA1c + Class A combo. I don't own SDA speakers but it sounds a very sweet combo.
    Cembros,
    Might be time to make a call to Rotel customer service if you haven't already.
  • danger boy
    danger boy Posts: 15,722
    heiney9 wrote: »
    agreed.. amps take time to heat up enough to cause it to shut down because of to much heat build up.. something ain't right with your amp.. as someone mentioned earlier.. check each and every speaker wire.
    this caused a problem for a friend of mine. he sent me a picture of his amp.. and the first thing that popped out at me was one small speaker wire was touching the case of his amp.. causing it to shut down every time he pushed it.
    Interconnects can also cause a problem. I had that a while back. one back interconnect caused my amp to shut down.
    PolkFest 2012, who's going>?
    danger boy wrote: »
    Just had one fail on me the other night..........no warning at all.
  • dipiazza
    dipiazza Posts: 363
    make sure you dont have any bare speaker wire sticking out possibly touching the back of the amp or another wire. has happend to me before and will shut an amp/reciever down immediately
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
