Acrylic Dust Cover
SolidSqual
Can anyone suggest a place where I can get an acrylic dust cover for my TT?
Post edited by SolidSqual on
"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Oops maybe I should specify, can I get one around $100? That pro-ject model seems a bit inflated in price.
Try a local glass shop. Many sell and will fab boxes using Plexiglass/Acrylic. I had a custom cover made by a guy on Audiogon. 1854k was the sellers name. It ran me around $175.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
SolidSqual wrote: »Oops maybe I should specify, can I get one around $100? That pro-ject model seems a bit inflated in price.
That is their MSRP. Anything you find will be in that range. Maybe these guys can make one close to your price range:
http://www.jmkdisplays.com/turntablecovers.html"Just because youre offended doesnt mean youre right." - Ricky Gervais
I saw these guys but the are not getting back to me. -
SCompRacer wrote: »Try a local glass shop. Many sell and will fab boxes using Plexiglass/Acrylic. I had a custom cover made by a guy on Audiogon. 1854k was the sellers name. It ran me around $175.
Thanks for the tip, I'll look into it. -
You could make one out of some plexi from your local hardware store. The stuff is pretty easy to work with and all you would need to do is glue it together after you make the cuts.
Mike's not the ...um DIY type. I wouldn't do it either. The Audiogon guy is solid and he's made a couple covers for me on other stuff.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Yeah, I'm only comfortable working with wood and related power tools. Not sure about gluing, but I can sand and stain after adding a few screws.
I did however make a pair of isolation platforms for my CDP and TT. But that only required getting a piece of wood and adding some spikes. -
Yep. He's solid and within your budget.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Cool, the audiogon guy emailed me back right away and I'm filling out a form to send back to him.
$360 for a small plexiglass box...Link to my System Showcase...
"ES - Kind'a simple but I like it"
Sony ES STR-DA4300ES 7.1
Sony ES SACD SCD-C2000ES
Sony 400 Disc CD CDP-CX455
Infinity BU-2 Sub-Woofer
Polk Audio RT800i Towers
Polk Audio CS400i Center
Polk Audio FXiA6 Surrounds
Sennheiser HD 280 Pro Headphones
DH-Labs T-14 Speaker Cables
Panamax Max 500 DBS Line Conditioner
Panasonic TH-50PZ85U 50'-Plasma
Play Station III - BluRay
Logitech Harmony 550 Remote
Logitech diNovo Mini Keyboard -
Hey,
I heard back from JMK Displays. Their quote: 16"L x 13"D x 7"H: $78.80 + S/H to your location of $15.45.
For the same size, the audiogon guy is charging $208!
I'm looking into whether JMK offers cutouts for handles and wires like the audiogon guy. Once I know that information we can compare the value of each more accurately.
Mike -
Michael
NORTH of 60° -
Since turntables now cost $10K and up that probably isn't so bad. Although you would think that the cover would be standard, or at least an option, since turntables cost so much these days. Covers used to be standard equipment on good turntables.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I spent $1,200 on mine for TT and Phono. Trust me, $350 is too much for a dust cover that can be had for under $100.
I've spent money like an idiot in this hobby enough to know that buying a $350 dust cover is an idiot move. -
SolidSqual wrote: »I spent $1,200 on mine for TT and Phono. Trust me, $350 is too much for a dust cover that can be had for under $100.
Only $1200 for a turntable!! Don't let the audiophiles know that. They will tell you that is the starting point for a cartridge. And you need a seperate pre-amp for the cartridge, along with a low-mass, high rigidity, resonance free tone-arm. Then you can buy the turntable, along with the dust cover.
Seriously, although I will never go back to turntables, how big a differance are you experiencing in the sound between the turntable and CDs. Are you getting any feedback from sound vibrations being picked up by the turntable?Lumin X1 file player, Westminster Labs interconnect cable
Well, a 4x8 sheet of lexan (much stronger/scratch resistant than plexi) cost $100 but it is harder to work with. On the other hand, a 4x8 sheet of plexi cost about $40 but is very easy to work with. A plexi cutter, stronge straight edge, a better 12 or $14 caulk gun and some fine silicone and I guy can make as many stabs a a nice box as it takes to get it right. Plexi really is a breaze to make straight cuts in if your box is going to have all right angles in it....Link to my System Showcase...
Mike - is the size you got the quote from JMK inside or outside dimensions? I need to get a cover made for my RM5-SE, and that's cheaper than a local shop will make one for.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
It's outside dimensions.
seems decent, if you get it put up some eye candy.
RT1
