Phono preamp advice...
TSWisla
TSWisla Posts: 446
edited February 2009 in 2 Channel Audio
Does anyone know or have an opinion about phono preamps? I want to improve on the sound from my TT (Project Xperience) and was going to send in my Carver m-4000t for a rebuild, but was thinking that maybe I should get a phono preamp instead. At what price point/brand should I be looking to get a big improvement in sound?
Zu Soul Supreme
Coincident Frankenstein mkIII
Esoteric K-07
Post edited by TSWisla on
  • ben62670
    ben62670 Posts: 15,969
    What cartridge are you using? MM/MC? I would go with a separate phono pre myself. Budget? Tubes? SS? What is your main listening preference?
    Ben
  • TSWisla
    TSWisla Posts: 446
    I have an all carver set-up, I listen to just about everything, but lately almost exclusively everything on vinyl. Budget? I don't want to spend too much, looking for the most bang for the buck. Hopefully less than 1500...
    Zu Soul Supreme
    Esoteric K-07
  • HB27
    HB27 Posts: 1,518
    http://www.mcalisteraudio.com/
    2/3rd's down the page is a very fine phono preamp. I've got one built into my McAlister Custom built preamp and it's as good as you're going to find for the money.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    The Acoustech PH1P is rather grand. If you go for it make sure you get the PH-1P. This is alot of preamp for the money very flexible and will carry you well into future TT purchases, the member I got it from had to spend over seven grand to beat it.
    RT1
