Speaker wire and Banana Plugs
Kchill
Kchill Posts: 262
edited February 2009 in Speakers
Over on Monoprice...great site if you need cables and such. As I look I wonder does banana plugs make a difference at all?
And just for spits and giggles, what do you recomend for wire from them?
Retired Onkyo 520 (returned broken HK 247)
Now a Pioneer 1018
CSi3
2- RTI10's
2- R50's
2- Fxi3's
Onkyo 250W Sub
Polk psw-10
"Inch by inch lifes a cinch, yard by yard life is hard"
  • TNRabbit
    TNRabbit Posts: 2,168
    banana plugs make switching out a lot easier, not much use if you don't switch out very often. I prefer spades or soldered/tinned leads in such case. 12 gauge is more than enough for most applications; if you're running really long lengths (100 ft or more) and/or a TON of power (300+ watts), 10 gauge may be more appropriate.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
