Can I use 3x expanding foam to remove cu.ft from sub box?
Rppngears
Rppngears Posts: 1
edited February 2009 in Speakers
So I built a fiberglass sub box for my 350z to fit under the strut bar knowing it would be too big. But, now I gotta figure out a way to remove .4 cu. ft. I could obviously just fill the box up with wood blocks but I'm not trying to make a boat anchor. So instead I was thinking I could just put some triple expanding foam in there. Not sure if this will work to effectively decrease the volume of the box though? Need some help.
Post edited by Rppngears on
  • seeclear
    seeclear Posts: 1,244
    Welcome to the club. You might get better responses over in the car audio section of the forum.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Yep...I'd take it to the car forum.
    By the way, welcome to Club Polk.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
