HOw will this subwoofer work with my system?
Pycroft
Pycroft Posts: 1,960
Hello all...
I've been researching subwoofers for the last few weeks. Here is what I'm looking at:
I currently have CS1, Monitor 30's (Front) Monitor 50's (Rear) with my Onkyo SR606. I am looking to add an Energy ESW-10 as a sub. How will that match with the system? Setup is in my family room 22x18.
Thanks,
Pycroft
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
  • thsmith
    thsmith Posts: 6,082
    edited February 2009
    at over 3000cf I doubt it will satisfy your LFE needs for home theater.
    Need to step up to a 12"350watts+ at a minimum. Check out HSU, outlaw and SVS. There are others but these are the ones I have experience.
  • Pycroft
    I would then like to see if people could rate the best subwoofers for less than 250 bucks. I am looking for 150RMS +. Size does not matter. I've looked at Infinity PS10, Energy ESW-10, Velodyne CT-80, and others. I know very little so would appreciate any and all imput - especially if you use them yourself. I will use it for 80% home theatre, 20% music.
    Thanks,
    Pycroft
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    Pycroft wrote: »
    I currently have CS1, Monitor 30's (Front) Monitor 50's (Rear) Pycroft
    Any reason why you are using the 30's as your fronts and the 50's as your surrounds? Seems backwards to me, I'm assuming it is due to a space restraint of some sort? Just curious, not trying to be critical.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • timmythugs
    timmythugs Posts: 71
    kds60a2000 has a warranty extension. Have you had any problems with your optical block?
  • Pycroft
    wutadumsn23 -
    I really have no space restraint - I always thought bookshelves should be used as fronts, and towers as rears? I'm new to this...is that backwards? What are the pro's/con's to having it switched?
    And Timmy - I'm not sure I understand your question. What is an optical block? Was that question even meant for me?
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • Pycroft
    Keiko -
    It's out of my price range. Unless someone is selling a used one for around 200 bucks, I'm off the market for the DSW. I'd love the suggestions to keep coming, especially if you've used the ones above.
    Pycroft
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • TheMARPATNinja7
    TheMARPATNinja7 Posts: 150
    Pycroft wrote: »
    wutadumsn23 -
    Towers=Fronts, Bookshelfs=Backs, or you can just get all towers (If money is no problem) but that also takes up a lot of room. Fronts get most of the signal in a 5.1 setup so you want to send all that sound to the most capable speakers that you have, which would be the towers.
  • Pycroft
    Would love some suggestions: There is a local guy selling a Cerwin Vega LW-12 sub. It seems to fit what I need, and I think Cerwin vega is a good brand. Any comments on this sub?
    Thanks again all,
    Pycroft
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • TheMARPATNinja7
    NOOOOOOOOOO!!!!! Not the Vega. The CLS-12S doesn't have the best electronics. I love the sound that mine had but it's not reliable. It has the auto on/off feature but no on/standby switch so it will randomly go off in the middle of something with no bass and the only way to get it back on is to flick the master power a couple of times. Mine is currently sitting on my porch waiting for ups to pick it up and never come back to my house ever. Get a Polk/Klipsch/JL Gotham.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Pycroft wrote: »
    wutadumsn23 -
    Yeah, I'd switch that setup around. The 50's would do much better up front, just as the 30's would do much better in back. The 50's are a more full range speaker, where as the 30's are somewhat limited, so they'd be much better off being switched around.
    Personally, I'd stay away from the Cerwin Vega. CV's are LOUD, but that's about it. The sound quality just isn't there. If it was exclusively for movie watching it might be ok, but if you listen to any music at all, I'd look into something else. CV's are loud, and have a lot of boom, but they're not punchy really in the upper bass regions, and I've always found them to not really be to accurate. They tend to sound sluggish and kinda muddy in my experience.
    One of my friends dads is an absolute Cerwin Vega nut...he owns like 4 pairs of them. His newest ones each have two 15's, a 6.5 inch midrange, and 1.25 inch tweeters. They're loud as hell...and they'll pressurize the hell out of your room...but the sound quality is terrible IMO. Great party speakers though when volume is the only concern...as is the case with him typically.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    250 dollars, I'd have to go with the current price at Onecall.com and jr.com for the Polk505. 300 watts, 12" 28hz low. Slot port. For 250 its hard to beat, for over 500 there are a lot of good subs out there. Velodyne, SVS, HSU, Sunfire, etc.
    I Know your budget is a problem just look for sales..especially online. If you don't mind the color white you can get the Boston Acoustics HPS-12HO (300 watts, 12 inch, about 46 pounds) Definitely worth 249? Free-shipping?
    That Yamaha mentioned above is not bad for the price either.
    I'd really think about the Polk PSW505
    cnh
  • comfortablycurt
    I'd have to agree with cnh on the PSW505. For the price point, that looks like a damn good sub. Never heard it myself...but there are quite a few people on board here that have it, and are thrilled with it.
  • TheMARPATNinja7
    Yeah go for the PSW505, I've only heard good things, when that CV is returned that's the sub I'm goin with.
  • vijayl
    vijayl Posts: 258
    I have PSW505 and has been sounding grt. I wud recommend it..
    BTW - if u have changed ur setting to be M50 as fronts, do it.
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
  • rdb2001
    rdb2001 Posts: 791
    cnh wrote: »
    cnh
    +1 to the boston acoustics 12. I have two of them and for what I paid for them I think they are hard to beat for the price. Very musical. They have very tight accurate bass and is solidly built at around 55 pounds. One call use to have them in the midnight color.
    I agree, the B.A.s tend to be very 'musical' for 12" subs. I really think that's their strength. And I own one as well.
    Got mine for almost nothing...! Also have the previous XB6 B.A. which I plan to add to the mix.
    cnh
  • Mike21
    Mike21 Posts: 252
    Check this out:
    Polk PSW 505: 12" x 300w; 28Hz $225
    Sony SA-W2500: 10" x 100; 28Hz $80 refurbished direct from Sony
    Take a look:
    http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&productId=8198552921665094083&langId=-1
    I have one 2500 and it performs way above its list price of $100. I just bought a second one (refurbed) today. You could get two 2500s for the price of one 505.
    As cnh can testify, 2 subs are better than one.;)
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • TheMARPATNinja7
    One PSW505 is better than two entry level sonys. Plus the PSW505 goes below 28hz, I know it's advertised as that, but I've tested it at around 23-24 and it gets there.
