Front Speaker Suggestions
I'm looking to set up a 7.1 system. The rear four speakers will be from the RM10 line. I'd like to get a fuller sound from the front (and I'm sure I'll end up changing the backs later) but I am undecided on what to use. Here's what I've found...
These are all being liquidated at CC:
Tsi100 - $160/pair
R300- $150/each
M20- $110/each
I'm concerned that the M20 wouldn't be much of a an upgrade over the Tsi100. I don't want to overpower my backs, but I won't be surprised to catch the upgrade bug. I do plan on switching out the center, but won't even worry about that until I picked the fronts.
I've also considered trying my luck for some Monitors on polkdirect.
Any ideas? Thanks!
Tsi100 - $160/pair
R300- $150/each
M20- $110/each
Any ideas? Thanks!
Onkyo TX-SR608
Panasonic DMP-BD60 Blu-ray
Xbox 360
Fronts- Monitor 50's
Center- CS1
Surrounds- Monitor 30's (side), RC60i's (rear)
Sub- PSW10
Samsung 50" B650 Plasma
Xbox 360
Center- CS1
Sub- PSW10
Post edited by jwalk40 on
What is your budget
I'd like to find something for about $250/pair (especially knowing I'll still need to upgrade my center channel). This "small" theater install is quickly rising in cost and I don't think my wife will appreciate any more.
These would likely migrate to the back later, so I can always go better in the front later. Seems silly to go much more expensive with the smaller speakers in the back.Onkyo TX-SR608
Xbox 360
Center- CS1
Sub- PSW10
