psw 250 connections
ctgraham
I Have my psw250 connected to a system with the rm6200 surround speakers. I am using a Harmon Kardon AVR 347 receiver. The speakers all sound great with the exception of the sub. I am getting little to no bass output and a fair amount of feedback. Any suggestions on how to fix this issue? I have tried adjusting the volme levels and all that does is increase the feedback. I am fairly new to this so im sure I have something wrong
Post edited by ctgraham on
There is probably a setting in the receiver that allows you to set the bass to subwoofer or mains or both.
Try that it might help
TK -
Be sure your receiver is set to subwoofer = "off" or "none"
This is assuming you have your wires as follows:
a) receiver to the R and L speaker inputs on the sub, and
b) the 2 front speakers connected to the output channels of the sub.
Good luck!
