Best LCD for photo editing??
joeparaski
joeparaski Posts: 1,865
edited January 2009 in The Clubhouse
Some of you photographers may know this. However I need to keep this in the low 100's for pricing.
And....I think this should be post 1,000 for me.
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
  • manman
    manman Posts: 256
    edited January 2009
    I guess you're asking best at that price range and not best, cuz you'd definitely be spending a lot more than that to get the best. IMO it's going to be tough to get something with really good color accuracy in an lcd at a low price (i guess it depends on what size you're looking for too), but I would suggest just researching the major brands and seeing which ones rate the best at your budget. Brands like samsung, NEC, and I believe viewsonic is sitll good.
    Not sure if you're set on an LCD, but personally I think CRTs are still the way to go for any kind of image/visual design work. I have an lcd for regular daily use, but I use my CRT whenever I do image editing or anything like that. And these days you can get them at a good price since everyone is moving to lcd's etc. Just a thought.
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2009
    For that price wouldn't it be best to just stick with a crt? Cheap LCDs always caused problems for me because the top of the screen seems slightly lighter than the bottom. It was always a pain in the **** for me when I was using photoshop; almost like every file had a gradient effect.
