Type of wire for Subwoofer?
bae77345
bae77345 Posts: 2
Does it make any difference what type (coax, RCA) or guage of wire I use to connect my PSW111 subwoofer to my Pioneer VSX-1018AH-K? I am using a basic Sony coaxial cable http://www.target.com/Sony-Coaxial-Digital-Audio-Cable/dp/B000JWNP4W and I don't seem to get much sound out of it.
Thanks!
Post edited by bae77345 on
  • thsmith
    thsmith Posts: 6,082
    edited January 2009
    Nope, suggest looking at monoprice.com. I use theirs and they work great.
    Might check sub channel out on AVR to make sure it is set at least at -5 and the gain/volume on sub is set at least 1/3 way up.
    Could have bad cable or connector on sub or AVR.
  • bae77345
    bae77345 Posts: 2
    edited January 2009
    Is -5 a higher signal than +5 (+ vs -)?
  • Solumnus
    Solumnus Posts: 48
    edited January 2009
    Bae, +5 on the VSX-1018AH-K is higher than -5. I think he was trying to tell you to make sure the SW Channel Level was atleast -5 or more. I have the Pioneer VSX-9130THX-K and use (close your eyes veterans) Monster Cable SW cable. It runs my (crappy HTIB) sub. Make sure the direction on the cable is right, if there is one. If it still doesn't work I would put the sub close to the AVR and test it with just a speaker wire or RCA conection, if you have some spare. If it works then the Digital Cable is bad I would guess. Try monoprice.com for cables like thsmith said. Others say Blue Jeans cables or Signals are very good too. I have never used any of them, but after joining the forums here, I now plan to, when the wife let's me, lol.
    Toshiba 62HMX85
    Panasonic DMP-BD60
    Xbox 360 with HD-DVD
    Pioneer VSX-9130-TXH-K
    Polk Audio CSiA6
    Polk Audio RTi10's
    Polk Audio RTi4's
    Polk Audio RTi6's
    Polk Audio PSW505
