MIT interconnects series
Norm Apter
OK, so for those who are familiar with MIT series interconnects, I'm wondering if there is anything between the Shotgun series and AVT (I believe its called) series. Basically, I'd like to see if there are options beneath Shotguns that would be a definitive move up from what I have.
But just for fun, what is considered a reasonable/normal price for a used/good condition 1-meter pair of Shotguns? <<cringing>>
As you can see from my sig, I've got a combo of AQ diamondbacks & SC Analog IIs in my 2 channel at present. Trying to think of how to move up from here...
Been talking with Ben and Ben's silvers are a possibility for the next move up in ICs, but want to put all of my options on the table so that I can think long term.
Norm
Norm
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
HT
Denon 2808ci AVR
Post edited by Norm Apter on
Norm,
Around 320.00 for used/demo give or take although the price has been rising. I got mine a little at a time, I do recall once buying two sets of Joe Abrams demo sets and he did cut me a deal, I would suggest you talk to him.
RT1 -
Actually i did just check A-Gon and these are a deal as far as price.
http://www.audiogon.com/cgi-bin/cls.pl?cablintr&1237849191&/MIT-shotgun-s3-interconnect -
The order is AVt(3, 2, 1), Shotgun(3, 2, 1), AVt MA, then Shotgun MA.
I haven't heard the regular AVt series, but have been told there is a audible difference between them and the Shotgun. You'll also have to move up to the Shotgun series for adjustable impedance networks and locking RCA's."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Thanks, guys, for the info and the heads up. That does seem to be a great deal (on the pair in A-gon)...though these particular pairs will probably get snatched up before I can make a definitive conclusion on the route to go, if they haven't already. But all of this helps...2 Ch.
HT
Denon 2808ci AVR
