Distance betwween mains
What is the ideal distance between the front mains for HT? Right now main are about 6 feet apart because of room constraints but I'm guessing they should be more like 10 feet about ideally.
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Post edited by DannyD on
For HT? It all depends on the room, distance to listening position, size of the TV, and personal preference. A good rule of thumb is that it should be equal or less than the distance to the seating position; some other things to consider: not too far away from the TV, not too close to side walls. Usually the position is limited by room size. If space allows, experiment a bit and see what you like best._________________________________________________
What Ricardo said. And also, the beam-width of the speaker will have a lot to do with ideal distances.
For some great room set-up advice, check out Dolby's room layout guide at:
http://www.dolby.com/consumer/home_entertainment/roomlayout.html
