polk sda-1c 12" passive radiator
nooshinjohn
nooshinjohn Posts: 26,002
edited January 2009 in Wanted (WTB) Classifieds
looking to replace of of my passive radiators in my 1c's
thanks
Post edited by nooshinjohn on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    What's wrong with your old one?
    Ben
    edited January 2009
    sounds a bit metallic, looks like somebody tried spray adhesive to make a repair and it ate the styrofoam
  • ben62670
    edited January 2009
    I hate to do this in a wanted thread. You may want to make a help needed thread. Can you pull the driver and see if anything is loose. You may also want to(should) apply some sound deadening material to the basket of the PR's spokes.
    Ben
    edited January 2009
    looked it over good yesterday. there is no support left in it and even the slightest movement causes the noise. there are weights on the bottom of the styrofoam, which leads me to believe they were balanced at the factory to optimize performance. if not for that, I would attempt to repair them myself
  • Face
    Face Posts: 14,340
    edited January 2009
    I have one that I believe works, but has marks from someone's cat.
    First, find out if you can fix yours, then we can talk about the ugly one I have here.
    edited January 2009
    Thanks! will let you know
    edited January 2009
    thanks for that brett. I am watching it for now
