hdmi inputs on receivers
Knucklehead
Knucklehead Posts: 3,602
edited January 2009 in Electronics
ok...ive read many posts on hdmi inputs that actually do nothing for audio. what is the main purpose of the hdmi input?:confused:
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan
Post edited by Knucklehead on
  • MADGSF
    MADGSF Posts: 603
    edited January 2009
    To allow 1080P video signals a path. The HDMI interface is the only leaglly licensed connector that can be used for 1080P signals that I know of. I think there is a bandwidth issue there to as the HD audio signals need the high bandwidth available with HDMI. It also cuts down on the number of cables you have to use for a connection which is always a plus.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • Bass_Pedal
    Bass_Pedal Posts: 196
    edited January 2009
    The HD audio formats can also be sent to your receiver via analogue cables if your BD player has on board decoding for the HD formats.
    Mains - Vienna Acoustics Mozart Grand
    Subs - Rel T5 x 2
    Amplification - Bryston 3b cubed
    Pre Amp - Marantz Sc11-1
    SACD - Marantz Sa11-1
    Stream - Cambridge Audio CXN v2
    Dac - Marantz Dac-1
    TT - Pro-Ject RPM 9.1 w/ Ortofon 2M Black Cartidge
    Phono Stage - Project Tube box DS
  • Knucklehead
    edited January 2009
    thanks for the input, but what im actually talking about is the hdmi input on the back of the receivers, ive read that this just passes hd audio through the receiver and out to the t.v rather than to the speakers, if that is in fact true, whats the point of these inputs on receivers?
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited January 2009
    Those are there simply so you can use your avr as an HDMI switcher. Most newer AVR's have the ability to pull the audio off the HDMI, if you choose to do so, and send it to the speakers but some of the older/cheaper ones do not. If you are buying a used piece of equipment, this is good info to have. A buddy of mine recently bought a used Onkyo receiver and got it all hooked up only to find out that it would only do HDMI switching/pass-through and could not pull off the audio. He's still trying to explain that purchase to his wife.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2009
    Some, but certainly not all, receivers only pass video through their hdmi input. My Yamaha 6160 (identical to the 663) does pass audio through the hdmi input and in fact also decodes Dolby HD and DTS Master HD signals as well. The receivers that only pass video on the hdmi input don't even send a signal to the TV speakers. On those receivers you also need an optical or coaxial connecter from the source to the receiver. On my Yammy HDMI handles all audio and video signals on one cable.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2009
    HDMI source input, which includes video and audio, would be received by the avr and then the audio portion IS sent to the locally connected speakers of the avr.
    The HDMI audio content is then processed internally by the avr (or not), amplified and passed on to the speakers connected to it.
    Whoever told you that HDMI audio only gets passed thru an avr does not understand the 'data flow' thru an avr or its purpose.
    Erik
  • Disc Jockey
    edited January 2009
    Erik Tracy wrote: »
    Erik
    This is not necessarily true. If the hdmi inputs on the avr are pass through only, the avr perform just like any other hdmi switcher and an additional cable will need to be run for audio to the avr. If the hdmi inputs are set up as repeaters, this allows the avr to process the audio portion as well as providing the switching functionality.
  • Knucklehead
    edited January 2009
    thanks for clearing that up for me...so...im assuming that a seperate hdmi switcher will do the same thing as a pass thru AVR..i think im catching on...after all i am a knucklehead!;)
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
