Help picking speakers, new to Polk
mu1166
mu1166 Posts: 172
edited January 2009 in Speakers
Finally got the wife talked into upgrading my home theater. I have a Bose Acoustimass 10 system now mostly due to the size factor. I sold my NHT setup to go to the Bose, what a downgrade. Having the wife happy makes my life much easier though.
My coworker has a Polk RM7600 system that I just love the sound of. I'm looking for some insight on a good route to go. Those speakers are about as large as I'm looking for. A little bit bigger wouldn't be a big deal.
Any ideas/options would be great. Looking to spend 600-1000 and the sub would/could be optional for now.
thanks
AVR: Pioneer Elite SC-67
Mains: Polk LSiM707
Center: Polk LSiM706c
Rear: Polk LSiM702F/X
Sub: SVS PC12 Ultra
TV: Panasonic VIERA TC-P60GT50
DVD: Xbox 360
NMT: Popcorn Hour C-200
Post edited by mu1166 on
  • organ
    organ Posts: 4,969
    edited January 2009
    How about the OWM series? Should have super WAF.
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    I don't know to much about the Polk speaker line. I have heard the RM7600 and that's about all. The wife factor is alright with some bookshelf speakers and I was going to take advantage while I can to get rid of the Bose system.
    I'm looking for some options.
    My previous setup was 5 NHT SuperOnes. I never did get around to buying a sub. From there, came the Bose setup and I've been crying for the last few years....
    thanks for any/all help.
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • Retro152
    Retro152 Posts: 985
    edited January 2009
    Cry no more, Grab the Rm7600 setup, which you said you have heard, and get rid of your current piece of "Crap". I had the Rm6750 system and thought it was great. The 7600 is a much better system and i think you will be quite happy, plus you wont need a box of Kleenex.
    Receiver: Pioneer Elite SC-05
    Amp: Emotiva Xpa-3
    Front L/R: POLK Rti-a9s':D
    Center:POLK Csi-a6
    Rear surround's:POLK Rti-a1s'
    Sub: Klipsch Synergy sub-12
    Sony Kdl-46w4100 46" LCD
    PS3
    Audioquest type 4 wiring.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    If you wanted to go the bookshelf route, you might want to look into the RTiA1's, with a CSiA4 center channel. You could also look into the older versions of those same speakers and save a few more bucks. The RTi4 and CSi3. That would be a great setup that would fit nicely into that price range.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    Would there be a noticable difference between going the RTiA1 setup versus the RM7600?
    I'm not finding much of the RM7600 for sale anywhere. I did find one on the web. I'm not even sure if it's a good deal or not at $650.
    My room is about 17x22 if that makes any difference.
    How would the RM95 setup compare to these 2 options?
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • comfortablycurt
    edited January 2009
    The RM7600 is an older model...so they probably are kinda hard to come by now.
    I've never heard the RM7600 personally, but there would probably be a pretty big difference in sound between that and the RTi's. For 650 bucks for the RM7600, you'd be better off spending a couple hundred extra and going for the RTi's in my opinion.
    The RM95 package is probably great as far as little sat/sub packages go...but it wouldn't be able to hold a candle to the RTiA1's with a CSiA4 center channel.
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    I don't have alot of places to go to listen to any new Polk speakers so just seeing what some other people think. Happens when you live in the middle of nowhere.
    I know that the RM7600 is an older model, but it did sound very nice when I was listening to it.
    I might take a look into the of the RTi models and see what's out there. Hopefully will be able to get somewhere to listen sometime.
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • Montoya
    Montoya Posts: 506
    edited January 2009
    The VM series are awesome you can get them from Polk direct for a good price. My wife loved the look of them and she is picky.
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    Is there much difference between the RTiA1's and the RTi4's? I'm really leaning going that route at the moment. Same question applies to the CSiA4 and the CSi3?
    Thanks once again
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • Upstatemax
    Upstatemax Posts: 2,739
    edited January 2009
    mu1166 wrote: »
    Thanks once again
    The one main difference I know of, the Rti-A's look better (IMO) since they taper in toward the back, they are not just a "box".
    The Rti-A1's are also reviewed VERY well.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2009
    mu1166 wrote: »
    Thanks once again
    I have the RTi4s (rears) and the RTiA3s (fronts).
    This is just me....but...if you can find the RTi4s for considerably less than the RTiA1s - then go for the RTi4s - they are a gem of a value and wouldn't give much away in sonic difference to the RTiA1s.
    If you are trying to eek out as much sonic goodness as you can in your budget and can afford the RTiA1s -then go for those.
    but - that's just me...
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    I never did mention my receiver if that makes any difference in this situation. I have an option of 3 different ones at the moment.
    Harman Kardon AVR 430 (Pretty sure this is the number)
    Integra DTR 6.4 or an older Yamaha HTR receiver.
    I kind of like the options (HDMI switching) that the Onkyo TX-SR606 has for an entry level receiver. It seems to have everything I would want in a receiver.
    Any of these receiver work better with Polk speakers than the others?
    I like the look of the RTiA1's but for the cost difference the RTi4's look to be the better option (179.99 for a new pair).
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • Erik Tracy
    edited January 2009
    mu1166 wrote: »
    Hmmm...I really like the RTi4s, but for that price you may want to consider waiting for a pair of refurbished RTiA1s to show up on Polks ebay site.
    As a comparison, they had RTiA3s(refurb) for $219/pr (still have to pay tax and shipping). I can't recall what the "buy now" price was for RTiA1s on Polk ebay, but it has to be less than $219.
    Your call...just stirring the pot... :D
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    Yes, you are stirring the pot. I'm open for all ideas. Hoping to get a system that I won't have to update for quite a number or years, or I get another itch to buy something new....
    I only found the new RTi4's at Crutchfield.com. For that price difference I may wait around a while. No harm in that. Have to keep my eye on the Polk ebay store. All kinds of options.
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    Since I really don't have a problem with used, as long as it's not abused. I found a pair of mint RTI6's along with a CSi5 in cherry color for $350 including shipping? Is this a good deal for the 'older' model of speakers?
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • comfortablycurt
    edited January 2009
    mu1166 wrote: »
    That's a very good deal. Snag it up before someone else does. Those are some great speakers.
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    Would those be alright with any of my receivers I already have until I purchase a new one?
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • comfortablycurt
    edited January 2009
    mu1166 wrote: »
    I'm not really familiar with any of those receivers, but they should work just fine. Those are 8 ohm speakers, and don't require huge amounts of power to be driven efficiently.
  • taketheredpill9
    taketheredpill9 Posts: 16
    edited January 2009
    Go the Polk eBay store and pick-up some vm series speakers. They sound and look awesome. Fed-ex dropped off a set of vm30's today!
  • daboyz
    daboyz Posts: 5,207
    edited January 2009
    mu1166 wrote: »
    Don't walk.........RUN and get these. You can get an Rti4 for rears and you will be ecstatic. Your current AVR(s) will run them adequately but not up to full potential. Get the speaks first then we'll discuss how to run them.
  • comfortablycurt
    edited January 2009
    daboyz wrote: »
    x2. He's lucky I'm not trying to get there before he does.;)
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    I tried running to get them, but email is only so fast. I may have missed out on that option but I'm still on the prowl for some nice speakers. Whether it be something out of the RSi series or maybe even and old RM7600 type system. Even though I think everyone on here has me leaning towards the RSi series system.
    How do the VM series of speakers stack up against the RSi series? Just a plain curiousity type question.
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    I think that I am going to try and get some of the Polk refurb'd speakers. Most likely going with 4 RTiA1's and a CSiA4 unless there is a absolutely great sale on the RTiA3 and CSiA6. I'll be trolling Polk's eBay site to try and snatch some up. I just missed out on the buy it now for the CSiA4 but we'll see where the bidding goes on it. Thanks for the help.
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • MADGSF
    MADGSF Posts: 603
    edited January 2009
    As far as an AVR goes the HK and Pioneer go great with the RTi series speakers.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • JohnnyG83
    JohnnyG83 Posts: 18
    edited January 2009
    To the OP. Wow, what a very small world. I have been in the process of slowly upgrading my HT too. Guess what I am upgrading from? You got it, Bose AMS10! I used to work at a Bose store and picked up the set for $400; couldn't pass it because I knew I could make a profit off of it.
    Anyway, like I said, I have been in the slow process of upgrading. I just recently bought a the RTiA'1, let me tell what a difference it has been so far; the speakers are absolutely amazing and I am still in the break-in process. I am powering them through a Denon AVR789 (that was my first upgrade in the process, used to have a Sony).
    My next step which I will be doing this Friday is ordering the CSi A4 for my center channel. So with my recent experience, I would recommend going this route. I didn't listen to the A1's before I bought them; I just went by word of mouth. I heard the TSi's and thought they sounded great but also heard that the RTi A1's were twice as good and they are.
    The biggest challenge will be my subwoofer. I am thinking about the DSW Pro 500 or DSW Mircropro 1000 alone with some other brands.
    The RTi A1's msrp at $349 per pair. I got them on Amazon brand new for $213. The prices jumps back and forth by the week. So I would pay attention to that. The CSi A4 is going for $208 brand new right now (normal msrp is $349).
  • JohnnyG83
    JohnnyG83 Posts: 18
    edited January 2009
    Oh btw, the A1's are acting as my main L/R.
  • MarvC
    MarvC Posts: 13
    edited January 2009
    For what it is worth I just sold my RM7600 speakers these are roughly six year old technology speakers with good performance.
    I ordered a set of the RTi A1's for the front and a set of Rti 4's for the rear initially.
    These made a world of difference in the sound of my system compared to the RM7600's.
    I ended up sending the RTi 4's back for a pair of RTi A3's for the front mains while the A1's were used for the rear.
    Both the A1 and A3 speakers have more low end from my comparisons with better high tonal quality then the RTi 4 units.
    If on a budget go with the A3's on the front and the RTi4 on the rear (these can be found for less than 200.00 a pair).
    I fell in love with the system described above the RTi A3 in the front RTi A1 for the back and the new Velodyne DLS-4000R which replaced my older Polk PSW 450 I tried the DWS 400 and auditioned the 500 and 600. The Velodyne is a masterpiece at this price level. The DLS-3750R is one step below the one I purchased another incredible buy for the price.
    I have the CSi A4 center speaker. All this powered by an Onkyo TX-SR606 receiver.
    It takes my breath away with the above compared to the RM7600 series I sold.
    :cool::cool::cool::cool:
  • Pycroft
    Pycroft Posts: 1,961
    edited January 2009
    I just bought the following:
    2 Polk Monitor 30's (Fronts in the home theatre)
    2 Polk Monitor 50's (Rears)
    1 Polk Monitor CS1
    They sound great together. Best news was I got the whole deal for 369 dollars from Newegg.com.
    I recommend them. I'm not an audiophile, but think they sound fantastic. I have them paired with an Onkyo SR606 receiver.
    Pycroft
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • mu1166
    mu1166 Posts: 172
    edited January 2009
    Thanks for all the replies everyone.
    Once again, I lost out on Polk direct on eBay. I clicked on a CSi4 to do the buy it now at 149.99 and it was already sold... Need to be quicker in looking on that site I guess. From everything that I've heard, the RTi A3 or A1 for mains and surrounds with the CSi4 for my center is what I'm planning on finding. I don't think I'll purchase new unless there is a great deal somewhere. Planning on using Polk eBay store as much as possible.
    Mains: Polk LSiM707
    Sub: SVS PC12 Ultra
    DVD: Xbox 360
  • NashG
    NashG Posts: 1
    edited January 2009
    Hi.
    that's really great.It's appreciable.thanks for the information.
    Used Cars
