Basic question on HDMI connection
Norm Apter
Very new to the Home Theater world, here, and thus have a question....
I've just bought an AVR with a few HDMI ports. I also have HD ready television with one HDMI port. But I do NOT have HD cable service (long story short is that basic cable is included in my rent so I just have basic cable) and at the moment I have only a STANDARD DVD player.
I will be picking up a BLU-RAY player some time in the coming months (and I've already picked up an HDMI 1.3 cable in anticipation), but given my current set-up, here's my basic question: would there be any added benefit at present to using the HDMI cable to link my AVR to TV (there is no HDMI port on my current DVD player).
Here's the way things are set up at present:
cable box --> TV (standard basic cable)
cable box --> AVR (RCA cables for audio)
DVD ---> TV (Component Cables for video)
AVR < ---> DVD (coax cable)
My AVR (Denon 2808ci) has tons of possibilities for connecting to other sources/components, but the manual --which, I am working my way through -- is pretty confusing.
So, in sum, the basic question is whether, with only basic (non-HD) cable service and a standard DVD player, an HDMI cable would bring any benefit in either video or audio (over the connections I've listed above)?
Norm
Norm
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
HT
Denon 2808ci AVR
Post edited by Norm Apter on
Norm Apter wrote: »So, in sum, the basic question is whether, with only basic (non-HD) cable service and a standard DVD player, an HDMI cable would bring any benefit in either video or audio (over the connections I've listed above)?
Norm
Yes there would be a benefit, at least for the DVD, maybe even for the cable.
The reason is that you get less analogue/ digital signal conversions which improves quality.
with a component cable:
If you play a DVD your signal is digital (DVD media is digital) -> then it's converted to analogue (for the component cables) -> then the TV converts it back to digital (because your TV can only play digital).
If you use a HDMI cable:
The signal remains digital from the DVD to the TV, and the only manipulation is the image processing in the TV.
If your cable box is digital then the same goes for cable."If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'" -
I think the main benefits would be slightly less cabling, ability to hear Dolby Digital on your cable channels (you could also get that with coax or optical from the cable box), and upconversion of the video run through the 2808, which may or may not be better than what your TV already does. And also simplified source switching, since you'd be using the same TV input, but that kind of depends on what you're using for a remote.
Other than getting digital audio from the cable box, I don't think you'd see or hear any quality differences. Component and HDMI look the same from my cable box, and you said the DVD player has no digital video, so that's what it is unless you like the 2808 video upconversion. -
Agree highly doubt you will see any noticeable difference with basic cable via component vs HDMI.. Even with the DVD player you probably wont see a difference in PQ...(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
(2) Panny DMPBDT110 3D Standalone Players
Panny 60" 3D Plasma TC-60ST30
Panny 50" Plasma TC-P50G10
Panny 50" 3D TV TC-P50GT25
Denon AVR-891
Harmoney One Remote
Polk Monitor 70's,Polk CS2, Polk Monitor 40's
