Onkyo 805 and Wii
CaligulaPolk
CaligulaPolk Posts: 1,650
edited January 2009 in The Clubhouse
I hooked up Wii to Onkyo 805 and I noticed the screen is shaking a little. Plus letter is blurry and messed up. Whats up with that and can it be fixed?
HDMi is hooked to tv from receiver "out". Is this why Wii is shaking because of hdmi??
yea i know this is not onkyo forum, but want to ask polkies if any1 know solution
I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
Post edited by CaligulaPolk on
    edited January 2009
    I don't use a Wii. But I would ask if you're just using the HDMI pass through or upconverting through the Onkyo. The 805 only upconverts to 720p that could be a problem.
    I'm not that familiar with the Wii. But isn't the Wii a SD 480i/p output? With a Wii you're probably best just hooking it directly to the TV via RGB component cables--in fact doesn't the Wii only have RGV--do you have that hooked up RGB to the Onkyo (if so I think the Onkyo only deinterlaces 480i to 480p and then sends that over HDMI and there could be a problem with that entire chain)
    , you really don't gain anything through HDMI (except audio, I suppose, and one cable operation if that's important to you). I have heard of issues with the Wii and Onkyos. I'd contact Onkyo directly or maybe even check their site for reviews of such issues?
    Sorry if this post isn't as helpful as it should be.
    cnh
  • CaligulaPolk
    edited January 2009
    cnh wrote: »
    cnh
    this is what I suspect.
  • ND13
    ND13 Posts: 7,601
    edited January 2009
    My Wii will only hook up thru composites. At least I haven't seen anything else.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • MikeC78
    MikeC78 Posts: 2,315
    edited January 2009
    ND13 wrote: »
    You can use component also, thats how I have mine connected.
  • CaligulaPolk
    edited January 2009
    I am hooking up component wires too.
    Is there anyway i can set onkyo 805 to 480i for WII only? I tried find it on manual and nothing. I will contact tech support on monday 9am to 5pm.
    But if anyone got solution, please do share.
  • acsubie
    acsubie Posts: 773
    edited January 2009
    i have mine hooked up thru component on the 805 and do not experience that problem, what source output on the 805 are you using? i have mine using DVD..also check your tv settings on on the Wii menu
  • ND13
    ND13 Posts: 7,601
    edited January 2009
    If you're not getting an HD signal from the Wii, then why pay for the components? Not an **** ?, just wondering.
  • MikeC78
    edited January 2009
    ND13 wrote: »
    Why pay? It's like maybe $20 for the special cord because there is that special connector on the back of the Wii. Anyway, component is used because my AVR will at least upconvert the 480P(?) max res of the Wii to 1080p via component. I can't do that using the composites.
  • CaligulaPolk
    edited January 2009
    acsubie wrote: »
    Game / TV
    What is your wii settings set at?
    ND13 wrote: »
    Wii is not HD gaming. Im using the wire it came with wii??
    thats why my screen is little shaking becuz i suspect HDMI has do somethign with it. I will try and play around wii setting and 805 settings to see if modification will stop the shaking. Well shaking is not that bad but annoys at the first time, i guess eyes will get used to it when playing few games.
  • ND13
    ND13 Posts: 7,601
    edited January 2009
    MikeC78 wrote: »
    See I don't own an AVR or anything Multichannel that processes/upscales anything, except for my Tosh XA1, PS3, and XBOX 360/hd dvd combo...none of which will read the Wii or Gamecube discs. I'm sure that my HDTVs won't do anything but use the signal they receive. Not a big HT guy, here. My 2.1 HT works pretty damn good for me.
