Choosing the best speaker wire
rengnath
rengnath Posts: 118
edited January 2009 in Speakers
Hello, I am currently moving so I am going to be setting up my system again so its the perfect time to make upgrades. I was using some speaker wire from ace hardware (16ga) and I now want to upgrade to something of a higher quality. The longest run I have to make is 30ft max (running it up into the ceiling) and that will be to a set of Monitor 7's in the rear. Ive been looking at Monster XPHP and you can get it off ebay for about $90 shipped in a 100ft roll otherwise for the same roll it is $100 from best buy. Is that going to be a good wire to run a high level into my sub, and then to my front speakers which are rt1000i's? Good for longer distances without loosing signal? Is it overkill? I am open to opinions and recommendations, I just want real opinions, not ones from someone trying to make a sale at an electronics store. Also, are banna plugs a good idea or do you have to get expensive ones to keep the same quality as just running the wire through the binding post? Thanks.
AVR - Yamaha Aventage RX-A800
Amps - B&K Components ST2140 (for mains) and Parasound HCA-1000A (bi-amping center)
Mains - RT1000i Towers
Center - CS400i
Sub - BIC Acoustech PL200
My neighbors listen to very good music, whether they like it or not :cheesygrin:
Post edited by rengnath on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    ~M~ sucks. You can do much better for the money. Nanners are handy. I like Audio Quest. Many here like Blue jeans, and Signal Cable too.
    Ben
    Ben
  • rengnath
    rengnath Posts: 118
    edited January 2009
    Ok, Im running a yamaha htr5840 reciever. Are any of those going to be significantly better than another or am I better off going for the best priced one? Is a 16 gauge wire still ok to work with as well or should I go with 14 gauge? Thanks.
    Center - CS400i
  • dkg999
    dkg999 Posts: 5,647
    edited January 2009
    Look at the Beldon wire from Blue Jeans Cables. Significantly better than the generic Mudster speaker wire you are referencing.
    DKG999
  • Willow
    Willow Posts: 11,071
    edited January 2009
    ben62670 wrote: »
    Ben
    I think some guy named Ben, might make some as well !:p
  • rengnath
    rengnath Posts: 118
    edited January 2009
    Ok, will do. Thanks so much for your help Ben and DKG.
    Center - CS400i
  • rengnath
    rengnath Posts: 118
    edited January 2009
    Willow wrote: »
    I think I saw these on another post. Silver jackets on the wires i believe ... I cant remember.
    Center - CS400i
  • BlueFox
    BlueFox Posts: 15,251
    edited January 2009
    At the very least, get 12 guage copper stranded from the hardware store, and as others mentioned, look at anything other than the M word.
  • rengnath
    rengnath Posts: 118
    edited January 2009
    Ok, I shall never speak of the M word again.
    Center - CS400i
  • Willow
    edited January 2009
    rengnath wrote: »
    Speak to the guy I quoted...he's tha' man !
  • Menasor
    Menasor Posts: 283
    edited January 2009
    Currently using Blue Jeans 12 gauge and I love them!
    Fronts: Energy RC-70
    Center: Energy RC-LCR
    Surrounds: Energy Veritas 1.0CM
    Subwoofer: SVS PC12-NSD
    Receiver: Onkyo TX-SR705
    Amplifier: Denon POA-2200 w/ Ben's ICs
    Pics of my setup (click me)
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2009
    http://www.parts-express.com/home.cfm?CFID=5402814&CFTOKEN=22500056
    you can find nice wire here for HT application. Plenty of banana plugs and wall connector as well.
    RT1
  • ben62670
    edited January 2009
    I would check into AQ type 2 for longer runs of cheap wire. Also the Type 4 is an excellent cable for shorter runs. Look for cables used. People do move up the food chain. I am not doing speaker cables for now.
    Ben
    Ben
  • Willow
    edited January 2009
    ben62670 wrote: »
    Ben
    My bad thought you were !:o
  • ben62670
    edited January 2009
    I did for a little while, but they worked great in some systems, but were lacking lower end bass in others. Those were silver plated stranded cables. I still use mine on the highs:)
    Ben
    Ben
