New member Questions Monitor 10
salasg
salasg Posts: 172
edited January 2009 in Vintage Speakers
Hey fellow Polkies. New member with some questions. I have noticed on the site that RTA-15TL is listed on vintage speaker list. I don't see the 15T listed are these the same speakers? If not what is the difference? Next I have the opportunity to purchase a pair of Monitor 10 and 4A, $100 for each pair. Is this a good deal and is their a difference between the Monitor 10 and 10B, besides the cabinet color. Appreciate any feedback.
California Polkie
Gus
Post edited by salasg on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    They use different tweeters. The black tweeters with the leads on a slant are the most desireable(peerless). $100 is good if they are in good shape. As for the RTA15T I have never seen one.
    Ben
    heiney9 Posts: 25,447
    edited January 2009
    ben62670 wrote: »
    The 15 didn't come out until they discontinued the use of the sl2000 tweeter. There was only a 15TL (the TL standing for Tri-laminate in reference to the new tweeter line)
  • ben62670
    edited January 2009
    That's a good thing:) It's a straight upgrade from the SL3000 to the RDO198.
    Thanks H9.
    Ben
    Ben
  • salasg
    salasg Posts: 172
    edited January 2009
    I have a Pair of RTA-15T's and had to replace the tweeter in one. I replaced both so the pair would be equal in sound. I believe the replacement tweeters sent were SL2500. Tried to get original parts but no luck.
  • Big Dawg
    Big Dawg Posts: 2,005
    edited January 2009
    My understanding is that the very first rta 15's were designated T rather than TL, but that the two models are perfectly identical.
  • salasg
    salasg Posts: 172
    edited January 2009
    I replaced my SL3000 with the SL2500 as recommended by CS. Is the SL2500 the same as the RDO198. I keep seeing these mentioned in the posts. If not should I look at replacing the SL2500's in my RTA-15T's.:eek:
    gus
    F1nut Posts: 51,805
    edited January 2009
    If you had the SL3000, your model is the RTA 15TL regardless of what the label says. The SL2500 is the wrong replacement tweeter, but may have been all that Polk had at the time. That is, before the RD0's were available. You should replace both of them with the RD0198-1's, IMO.
  • salasg
    salasg Posts: 172
    edited January 2009
    Thanks f1nut,
    What do the RDO198 run for a pair. I dont recall what I paid for the SL2500's. Think it was about $70.
    gus:D
  • thsmith
    thsmith Posts: 6,082
    edited January 2009
    $48 per tweeter shipped if tell Polk you are a club member
  • salasg
    salasg Posts: 172
    edited January 2009
