i'm looking for a good subwoofer and a centre channel
patty_boy_1
Im setting up a home theatre system and I need some help finding a centre channel and a subwoofer. i have 4 front speakers 2 are energy tower speakers and 2 are cerwin-vega and my rears are 2 old fisher tower speakers.
My amp can handle 100 watts for a front channel. I have a budget of about $500. And can I put a down firing subwoofer on concert?
Post edited by patty_boy_1 on
You have four front speakers? Are they all running at the same time, or on seperate systems?
And I assume you mean can you put a down firing sub on carpet, not concert, right? If that is what you meant, then yes you can.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
concrete?Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
concrete?
Maybe that's what it was. In that case, the answer is still yes though. Concrete isn't exactly the most acoustical flooring choice though...The nirvana inducer-
ya there are 4 front.
Concrete my mistake.
tile on concrete i'm not sure if that make any difference. -
My HT has a Definitive Technology Prosub 100tl which is front firing. It is located in the basement on concrete. It does rumble pretty well but not as well when I had my HT not in the basement.
I would try to look for a sub that is not down firing and place it in a corner. I am wanting a Sunfire True Signature sub which at 2700 watts should make a differnece. You should be able to pick up a Sunfire Jr. sub used in your price range. Smaller version of the Signature but will rock very well also.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
thats kinda out of my price range do you have any other ideas?
what about a centre channel??
