McIntosh 4 vs. 8 Ohm Output Rating
LarryK
Can anyone tell me why McIntosh rates the same wpc output for 8 as well as 4 Ohms (frome what I can tell) where all other amps increase the power for 4 or 2 Ohms. Thanks
Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Surround: Polk LSiF/X
Sub: Polk PSW10
Amps: Rotel RB 993 &
Parasound HCA-800 II
Pre/Pro:Anthem AVM-20
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
Post edited by LarryK on
Most McIntosh amps use autoformers, similar to what you would see on a tube amp.
One advantage to autoformers is increased stability while driving difficult speakers. Most autoformer models can drive 2 or even 1 ohm speakers without a problem.
One other advantage: http://www.scowcroftandassociates.com/pdfs/McIntosh%20Autoformer%20Training%20Page.pdf
Here's some more info: http://www.stereophile.com/amplificationreviews/804mcintosh/"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
is there a downside to autoformers?my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Good question. Face?Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
Pre/Pro:Anthem AVM-20 -
I believe McIntosh is the only company using them due to patents or some thing like that. If you try this link, there is a pretty good explanation on the purpose of the autoformer.
http://www.zeroimpedance.com/products.html
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
