1.2 TL bass response
michaeljhsda2
michaeljhsda2 Posts: 2,186
edited January 2009 in Vintage Speakers
I've been listening to my monitor 10A's and the bass response on the 10A's are considerably better than the 1.2 TL's. WTF!!! How can this be? Well I decided to move the 1.2's back 4 inches and now they are 6 inches from the back wall. Voila!!! Room shaking bass now. Just saying...damn these speakers are awesome...:D:D:D
SDA SRS 2.3TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
    treitz3 Posts: 19,207
    edited January 2009
    Check all drivers. Move then in and out and see if any of them have any obstructions. Next, listen to each driver with your ear right up to it. Is it driving like the rest of them? Any abnormalities? Differences?
    The 1.2tl's kick **** but should not be ousted by the 10's.
    Also, do you have them hooked up correctly?
  • Face
    Face Posts: 14,340
    edited January 2009
    I had the same problem with a pair of SRS 2's. If I back them up to the wall, the room shakes but imaging weakens. Pull them into the room a foot or so, bass is lacking, but imaging is fantastic.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    Could it be that it's not really "less" bass, but just "different" bass? Your ears have a break in period too whenever you get a new pair of speakers.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2009
    An excellent point made here. It took a little time for me to make the adjustment to the much cleaner bass of high end audio as opposed to the really loud and car shaking bass of two Alpine 12" type R's with 900 watts in the back of my IROC-Z.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • comfortablycurt
    edited January 2009
    Fongolio wrote: »
    Hey...I've got two 12"Alpine Type R's with 900 watts in the back of my 1990 Firebird...sounds good with that hatchback roofline huh? Talk about some thump.
    There is definitely a big difference though between that and my home stereo. My home stereo is a much much cleaner sound...if I get out of my car and go inside and turn the stereo on, I find myself wanting to turn the bass up cuz I'm used to the car stereo.
    I'd give your ears a little while to get used to the TL's and then re-evaluate them.
  • Fongolio
    edited January 2009
    '89 IROC-Z 5 speed manual with T-roofs 305ci with chip
    Alpine 9160 HU
    Alpine eq with sub crossover control
    Infinity 5x7 in dash with Alpine something small amp
    Infinity 6x9 in side panels with Alpine MRV-1005 amp
    2 Alpine 12" 2nd gen Type R subs in sealed custom box with Alpine MRV-1507 amp
    1.5 farad cap
    Did all work myself
    Haven't played with it since August last year. I miss the speed and the sound.
    Driving a 2000 Neon and a 1998 GMC Sierra 4x4 for winter.
    Oh crap sorry I threadjacked
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • comfortablycurt
    edited January 2009
    Sounds nice.
    1990 Formula 350 5-speed here, CAI, intake, headers and full exhaust
    Alpine all around.
    Alpine CDA-9886 head unit
    two 5x7 Alpine Type R's up front
    two 6x9 Alpine Type R's in back
    two 12" Alpine Type R subs in a custom sealed enclosure.
    Alpine V-power amps, not sure of the model numbers offhand.
    4x100 watts powering the 5x7's and the 6x9's
    1000 watt mono-block powering the 12's(ok, so it's not really 900 watts, close enough...lol)
    That car never even really gets used anymore...I've been debating selling it lately actually. I'd probably put the factory stereo back in though, and keep all the Alpine stuff. I love that system. I'll keep it for when I get my 02 TransAm in a few more years.
    Sorry for the thread-jack.:D
  • michaeljhsda2
    edited January 2009
    treitz3 wrote: »
    It's all good now that I've moved them closer to the back wall. It's a night and day difference. Imaging was never a problem before and isn't now. Speaker placement is mentioned all the time in this forum and here is a perfect example of simply moving the speakers back 4 inches (now 6 inches from back wall) resulting in a dramatic improvement in bass.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    edited January 2009
    Face wrote: »
    In order to obey the triangle rule, I moved the 1.2's closer to my listening position. Bass was fairly good and I lived with it for over a year. Then when I acquired the 10A's and noticed that the bass was better than 1.2's, I decided to experiment and move them closer to the back wall. That's when everything changed for the better. Imaging has always been fantastic BTW.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    edited January 2009
    Compared to the 10A's, the 1.2 TL's were lacking bass, no doubt. It's amazing that simply moving them back 4 inches could make a difference but it surely did.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • ND13
    ND13 Posts: 7,601
    edited January 2009
    Something as little as a 4" move back can make a dramatic difference, but I doubt that even with the 1.2TLs(working properly) even further away from the back wall could be out-gunned by Mon 10s. I've had SRS 2 and I still have 10As and it was no contest between them in any category, especially bass response. There has to be something else, or your room is just got supernatural spirits running around **** with your head, telling you to sell those 1.2s to someone as fast as you can and for whatever they have in their pocket at the time. That way, by making you think you had gotten ahold of a **** pair of 1.2TLs( that were no doubt:rolleyes: out gunned by some Mon 10s), the spirits gave themselves more space in the room to screw around in......probably all dead wives of audiophiles with major WAF issues, that went to their death before their time and likely wacked by their hubbies who chose big-**** Polk SDAs over the the bitching.
    Glad I got that off my chest....
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • michaeljhsda2
    edited January 2009
    ND13 wrote: »
    LMAO...too funny Noel. The monitor 10's are excellent speakers. Bass response is unbelievable. I had no idea that these speakers would sound this good. Thanks again for selling me the Peerless tweeter. As a side note, I noticed that there was static coming from both speakers and this problem was solved by using contact cleaner on the fuse holders.
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    edited January 2009
    Sounds nice.
    Alpine all around.
    I'm glad you mentioned your Formula 350. I bought an 89' Formula 350 back in 1991 but had to sell it as I had to choose between paying my college tuition or keeping the car. :( I sure wish I still had that car. Super fast, great sounding stock exhaust, corvette engine. There's a nice one for sale in Maryland but 1000 miles away...
    SDA SRS 2.3TL's
    SDA 2B TL's
  • rayslifecycle
    rayslifecycle Posts: 511
    edited January 2009
    for y'all that love your F body GM cars
    This show has been cracking me up for years.
    The link to listen is in the first posters thread
    http://www.nsxprime.com/forums/showthread.php?t=33660
  • BrettT1
    BrettT1 Posts: 560
    edited January 2009
    What size room do you have your 1.2s in? How much breathing room do they have?
    Thanks.
    Brett
  • michaeljhsda2
    edited January 2009
    BrettT1 wrote: »
    Thanks.
    Brett
    20 x 14
    SDA SRS 2.3TL's
    SDA 2B TL's
  • ND13
    ND13 Posts: 7,601
    edited January 2009
    That's ample space for 1.2s. They should pressurize that space quite nicely. My old SRS 2s would do a 455 sq ft room.
  • comfortablycurt
    edited January 2009
    lmao! That's hilarious...
