PA 1100.5 and MM1240's
Roux
I just purchased the following for my truck:
A pair of MM6501 for the front doors
A pair of MM5251 for the rear doors
Two MM 1240svc subs and,
A PA 1100.5 amp to power it all.
I know I am going to run the components to the front and rear channels respectively. My problem is with the wiring of the subs. With the two SVC subs I can only run them in parallel to a 2ohm load. I was told that they will be powered sufficently. However, it seems that if I wire them that way each sub will only be powered by 280 watts RMS (140 watts to each sub). Where as if I had the MM1240dvc subs, I would be able to run them to 1ohm, which would produce 600 watts x 1 (300 watts RMS to each sub). Is this correct, or am I not understanding how they will be powered? Any help will be greatly appreciated.
Post edited by Roux on
those subs want way more juice, but if your set on that amp maybe u can port them. that amps not 1ohm stable is it??Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
