Rodent issues what to do?
disneyjoe7
disneyjoe7 Posts: 11,435
edited January 2009 in The Clubhouse
I have 2 fruit trees in my backyard, one being Grapefruit the other Orange tree. The issue I have is something is eaten the Grapefruit if that bad enough it got into my propane gas heater and eaten or damaged lots of control wiring. :rolleyes::eek::(:mad:
Ok I was thinking rat poison in the heater just below the control wiring area not the burner area, but I heard Mothballs instead. But don't know about Mothballs can I place them free on the bottom, in the box? How about water? Could it cause issues if they got wet? Would the balls rust out the heater? It's either steel or aluminum not sure didn't really matter to me. Any suggestions? I'm lost.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • obieone
    obieone Posts: 5,077
    edited January 2009
    Um, how about mousetraps? I don't recommend putting ANY kind of toxins near a source of heat.
    Can you see how they're getting in to the heater? Is this a package a/c & heat unit, that sits outside on a pad?
  • zingo
    zingo Posts: 11,258
    edited January 2009
    What about just putting a piece of mesh over the opening where they come in. Should keep them out and no chemicals near your food! As far as the trees, a neighbor of mine puts nets over his cherry trees to keep the animals away and I'm impressed how well it works. By the end of season, you couldn't buy better cherries if you tried.
  • disneyjoe7
    edited January 2009
    I agree I never place anything around my fruit trees. But ants and spiders are a PITA hate them. As far as the fruit its the best fresh off the tree. :) I got the Mothballs idea from a pool supply store, but thinking it maybe a way to get me to buy another one soon. Or maybe a good idea not sure.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Moth balls do keep rodents away. We used to use them in a cabin up in VT. If we didn't put moth balls in the closets, or the cloths chests they would make homes in there. Traps work best, but if you have pets you can use those little have a heart traps. If you catch one you can drown it in your pool:eek:
    Ben
  • disneyjoe7
    edited January 2009
    How it got in there is a mystery for me... But can say slots on sides and under a small 1"x1" or so hole (part of design, not damage) by gas logs? (Not sure what they are called) He built a nest on top of them but got in by that 1"x1" hole. I would think mouse, but the droppings are larger not mouse like. I was told rats can get shrink into very small size so that at least what I think it was anyway.
    If nothing else I need to fire that thing up once a week or so and spend some $$ on gas, as sitting there for months off just adds to my frustration. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Willow
    Willow Posts: 11,056
    edited January 2009
    Move up here, it's too cold to grow fruit problem solved...at least till May!;) guess there is one thing about being this cold
  • disneyjoe7
    edited January 2009
    Willow wrote: »
    You know I step away and thought along the same line. Remove tree. Food and Rodents leave. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • polktiger
    polktiger Posts: 556
    edited January 2009
    Could be squirrels. They like to chew on things especially wires. They can also squeeze into very small openings like rats and mice 1" x 1" might be tight, but 2" x 2" would be no problem for rats or squirrels
  • disneyjoe7
    edited January 2009
    polktiger wrote: »
    Squirrels huh? I have a heavy squirrel problem they love citus :rolleyes::(:mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::eek::eek::eek::eek::eek:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited January 2009
    disneyjoe7 wrote: »
    That 1"x1" opening maybe 1.5"x1.5" since I looked at a ruler.;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited January 2009
    That's was to be part of the last message but made 2 messages? Sorry.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Phasearray
    Phasearray Posts: 437
    edited January 2009
    buy an army of cats
    Receiver - Onkyo HT-R340
    Front - Pioneer S-HF21
    Center -Onkyo SKC-340C
    Surround Back - Polk R15 <--Ticket to club polk
    Subwoofer - Onkyo SKW-340
  • ben62670
    edited January 2009
    If a rat or squirel can get their head through they can get through.
    Ben
  • bikerboy
    bikerboy Posts: 1,211
    edited January 2009
    Hi,
    When we bought our house about 5 years ago we had a family of rats in our house. I found out we have the big gray norweigen wharf rats and the medium sized vietnamese roof rats here in seattle. Our house had the roof type. They can walk on the power lines so I call them skin tailed squirrels. Both rats and squirrels can get inside something if their head will fit. The moth balls will work but they dont last long. If you plug a hole use metal screen or sheet, the thicker the better. We used the 8" long snap traps and even that didnt kill the biggest one right away. We also found a 5 gallon pail of flour in a blocked off area behind the bathroom in the basement. So after removing the food and trapping the 4 rats we have been rodent free for the most part. But now the dogs have been sniffing under the hot tub so they must be in there now. Squirrels are just as bad here. They will eat most anything in the garden. Remove any fallen fruit and those guards that stop them from climbing up the trunk that look like a cone might work. They can jump very well so good luck.
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
  • disneyjoe7
    edited January 2009
    I got too admit my biggest problem with rodents and now I do think it's squirrels more then a rat is I at times have fruit on the ground at times that fallen. Something I need to fix ASAP as that is causing me CASH NOW. So as far as mothballs ok but don't last long or its best to fire it up and have a squirrel roost every week or so? Then my biggest concern about mothballs loose or in the box? Can they cause rust? I hate to make my problem bigger then it is now.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    billbillw Posts: 6,847
    edited January 2009
    Get a cat, or a pellet gun. Either one will solve your problem. The pellet gun would be more fun though...
    For rig details, see my profile. Nothing here anymore...
  • Willow
    edited January 2009
    What I wouldn't do to go to my backyard and collect fruit all year round!! :eek:
  • bobman1235
    bobman1235 Posts: 10,822
    edited January 2009
    I'm pretty sure mothballs (aka napthalene) are highly flammable, so putting them in close proximity to a flame (ie your grill) might not be advised.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2009
    Go with the rat trap connected to hair pin trigger on a cannon, its going to take out everthing in a 50 ft radius and might even get rid of some of your nosey neighbors.
    RT1
  • disneyjoe7
    edited January 2009
    Ok so I left with the weekly "Rodent Roost" test firing. With propane getting so expensive I didn't fire it up much, well I see it cost me one way or the other way.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • reeltrouble1
    edited January 2009
    large snakes are also an option, they offer recreation as swimming partners as well.
    RT1
  • disneyjoe7
    edited January 2009
    Willow wrote: »
    I'm not sure if you're religious or not sorry if you're not...
    But I think GOD heard that one. Woke up this morning to see the pool control which is in my master bedroom by a slider door was ON? Like the pump was running. I being half a sleep think WTF, but rolled over. Later I'm up and get a close look the Spa's on NOW WTF is the GAS running also :mad:....
    It gotten SOOOOOOOOOOOOOOO COLD last night / today, the pool controller went into "Freeze Protection" mode running the pump working values keeping the water moving. What just happen did the earth just flip on its Axis or something?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • chillywilly
    chillywilly Posts: 167
    edited January 2009
    Just get one of these
    FXi3 sats
    RTi10 fronts
    CSi5 center
    velodyne dps 10
    denon avr 888
    velodyne dps 12
    sammy lcd
    ps3 60gig
    wii for family
  • jflail2
    jflail2 Posts: 2,868
    edited January 2009
    barn cats...
  • disneyjoe7
    edited January 2009
    If I got that I would MOVE Screw the Rodents or the Heater. :eek:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
