Psw1000 boomy help
StevenFo2
StevenFo2 Posts: 11
Hello,
Not sure if my placement off or set up is off but my psw1000 sounds really boomy. I currently use the lfe input with the volume at 12 o clock, frequency set to 80hz and phase of 0. Is the boomyness the nature of the sub is this sub capable of tight bass? I tried lowering the volume but the boomyness won't go away till the volume is nearly 0.
Any advice would be appreciated.
Regards,
Post edited by StevenFo2 on
  • Montoya
    Montoya Posts: 506
    edited January 2009
    I'm not sure what the problem is but I can tell you for sure the sub is not boomy.
  • TheMARPATNinja7
    TheMARPATNinja7 Posts: 150
    edited January 2009
    A lot of boominess can depend on your positioning of the sub. Make sure it's free standing (not in a cabinet or anything) and preferably in the corner of a room. Also if it's possible, have to port (not the actual driver) firing into the wall. Sub's can sound entirely different depending on their placement in a room.
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2009
    I run mine off the front pre-amp outputs. It is in the center of the room in front of the TV. There is no boominess, but solid chest pounding bass. On Master and Commander with the volume cranked the cannon shots are literally felt. The sub volume is less than 1/2 up, and the low pass filter is between 60 and 120.
  • timmythugs
    timmythugs Posts: 71
    edited January 2009
    why the front pre outs?
  • BlueFox
    edited January 2009
    timmythugs wrote: »
    That is another way to hook up a sub. Set all speakers to large, of course you need speakers that are full-range, and leave the LFE circuitry off. When you use the AVR to separate the signal going to the speakers you are putting filtering circuitry into the signal path. This can introduce distortion. All the signal needed for the sub is available on the front pre-outs.
    Toolfan66 Posts: 18,292
    edited January 2009
    then why the left,and right rca jack's on the back of the sub?if all you really need is the left?
  • speakergeek
    speakergeek Posts: 555
    edited January 2009
    "Boominess" is generally a room/placement issue more than the sub woofer. You probably have some serious room gain in the 40-60 Hz region in your room. Also, if you have an SPL meter it would be useful to measure your sub's level relative to your mains. You may be running it rather hot if you are trying to ear it.
  • Pepi28
    Pepi28 Posts: 248
    edited January 2009
    I agree with geek. Placement is almost always the culprit when it comes to boominess.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • Steven_1085
    Steven_1085 Posts: 11
    edited February 2009
    Thanks for the help guys, I haven't moved the sub due to some room restrants but It has sounded a lot better, maybe there was a break in period not sure.
    treitz3 Posts: 20,207
    Where is your volume level at?
